Insulating Basement - Insulation - DIY Chatroom Home Improvement Forum
Like Tree5Likes
Old 07-27-2019, 05:59 PM   #1
Rewards Points: 44
Insulating Basement
When I moved into my house, the basement had a rodent problem. I did an attic inspection, duct inspection, etc., and was able to confirm that it was, for the most part, isolated to the basement because of entry points and food source (dog food).
My tolerance for ick is very low, so my spring cleaning was basement insulation removal (fiberglass batts) and TOTAL basement sanitizing.
Now I have the full view of basement to do hole filling, etc., which I will do with foam, copper mesh, caulking.
Then, the big thing, is to re-insulate the basement....
I am very hesitant to use fiberglass again, because the ease of rodent occupation is high, and when it gets contaminated it is hard to clean.
The basement is framed, so foam board would be hard because I would have to remove the current framing.
I am tempted to use closed cell spray foam, despite the cost, because it would discourage nesting (although I am confident I can exclude rodents through addressing holes, I still have PTSD and fear of recurrence). Other benefits are ease of cleaning, that it kind of further seals the basement over top of the holes I fill, and is moisture resistant (some of the batts were discolored from moisture from condensation).
Is the foam going to cause me grief. Should I stick to fiberglass batts?
prairiewind is offline   Reply With Quote
Old 07-27-2019, 06:21 PM   #2
retired framer
Rewards Points: 18,044
Re: Insulating Basement
It sounds like you are in good shape, no water leaks or anything. Condensation happens when warm moist air get to a cold surface so air getting around outlets and any others and insulation that didn't fit nice and tight. So the key is taking the time with fitting insulation like you have OCD and then make sure there are no holes for air to get in there.
Is the wall built tight to the foundation or did they leave a little space.
Is there a space at the top where air can get to the foundation from the ceiling joist cavity?
Do not use flat bottom gables with scissor trusses.
Old 07-28-2019, 06:55 AM   #3
Naildriver
chandler48's Avatar
Rewards Points: 3,462
Based on your fears, consider using Roxul insulation in batts. It fits snugly between 16" oc studs, does not sag, is water proof, vermin proof, fireproof, and mold proof. It also requires no vapor barrier, but it is a good practice to install one. $pray foam is good, but expen$ive.
Windows on Wash likes this.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is online now   Reply With Quote
Old 07-28-2019, 07:31 AM   #4
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,064
CC SPF will be definitively more expensive than Roxul batts. I think, as mentioned above, you air seal everything and then use batts.
Be sure to get putty pads behind what will be holes in the finished wall and make sure the finished wall is air tight.
Look up ADA (airtight drywall approach).
Be sure the rims are sealed and insulated as well.
Bud9051 and chandler48 like this.
Old 07-28-2019, 10:59 AM   #5
Rewards Points: 44
The basement is unfinished, so the walls are framed and open, with about a 1" space between the framing and the concrete. The ceiling joists and rim joists are open, too.
The experience of having contaminated insulation to remove was not pleasant, so the idea of having spray foam is appealing, as I would assume that although mice can chew through it, any tunneling would be isolated and infrequent. I am doing an exterior/interior mouse-proofing exercise, but will always remain paranoid.
I will mull over using Roxul. Although it is less conducive to rodents making nests, etc., I am just worried that if mice live on it or move around through it that it will get contaminated, and that it is difficult to clean.
I was thinking about foam board, but that would involve temporarily removing the framing, and would also be a bit difficult to manage around the rim joists. Also, half the basement is a crawl space (the house is a split level), so I can't actually remove the framing there, as it holds up the floor for the walkout level.
I think that with spray foam or foam board I may have to cover it with drywall to meet fire code, so in some respects, Roxul would be better for that. Plus, it would be easier to install in the rim joist area.
Half of the wall of the non-crawl space part of the basement is above ground, so insulation in my climate area is almost a must.
Old 07-29-2019, 08:35 PM   #6
Rewards Points: 2,388
Also from outside. Sheetmetal between siding and foundation. Around and under deck ledger. Plumbing, electrical and vents. Drier vent is often low to the ground and big gaps around it.
carpdad is offline   Reply With Quote
Old 07-30-2019, 06:14 AM   #7
You can remove a bit of the framing and slide the foam in that way if the gap is consistent. You don't want to leave an air gap in this case.
https://www.joneakes.com/jons-fixit-...--overview.pdf
Old Yesterday, 11:21 AM   #8
Rewards Points: 44
I think I will go half the basement with rigid foam, and half with Roxul.
I think I can remove a lot of the framing either temporarily, or permanently if I get foam that I can attach drywall to directly. Reinstalling the framing should be easy, I just have to learn how to put nails into concrete floor.
Being diligent with air sealing and vapor barrier will be my goal, especially at the foam board and Roxul interfaces. The foam board is ideal, just not suitable for the whole basement.
Old Yesterday, 02:46 PM   #9
Naildriver
chandler48's Avatar
I'm not following your "removing" the framing, putting in Rigid foam and sticking sheetrock to it, then putting up framing. What is that? Your foam will be much more expensive than Roxul, so why not frame it properly, install Roxul and be done with it?
Nealtw likes this.
Larry......
Old Yesterday, 05:04 PM   #10
Rewards Points: 1,730
batt insulation with vapour barrier on warm side is common in basements but lousy in cold climates.
a vapour barrier on warm side only works well when you have drying potential on the other side. Exterior house wrap is specially made to allow moisture to escape, in a basement you have soil on the other side of the concrete wall and water-proofing membrane.
No barrier is perfect and air/moisture always leak in and move through the wall. No foundation water proofing is perfect either.
So in a basement, you have moisture coming from the concrete and moisture coming from the house even when the barrier is used. Moisture that gets in can get trapped by the barrier and condense on the foundation, especially above ground.
Water reduces insulation r-value and can rot out wood framing if there's enough condensation.
It's best to have a complete thermal break directly on the wall that's unaffected by moisture (like 2" of foam or roxul board) to prevent condensation from ever forming. Roxul batt insulation can be put between the studs for extra r-value with no vapour barrier so moisture does not get trapped in the wall assembly.
The thermal break stops the condensation so you don't need the vapour barrier and the wall assembly has drying potential.
Code may still require a vapour barrier when batts are used even with a thermal break, so if you're getting permits and have the thermal break it's best to put just to pass inspection, then slash many holes in it just before hanging the drywall.
People starting doing fiberglass with plastic vapour barrier in basements before there was a good understanding of building science.
It's still done this way due to a lack of education and out of date codes.
Problem is it's too labour intensive - the framing has to be removed to put the thermal break.
Another good method is just using sprayfoam which is impermeable and has fantastic air sealing properties, but it's expensive and can potentially off-gas toxins if the foam doesn't cure properly on site.
This is only my opinion.
I am not in the business of any trade or topic I give advise on. I have previous diy experience plus good knowledge of theory. Attempt repairs at your own risk. Never jump out safeties - especially pressure switches - on a furnace for testing with fuel supply on; use a meter. Do not troubleshoot with live line voltage present unless there's no alternative.
user_12345a is offline   Reply With Quote
Old Yesterday, 06:37 PM   #11
Rewards Points: 44
Yeah, I could have been a bit clearer. There is currently framing, but I can't fit rigid foam behind it. So, I would have to remove the framing. I saw some rigid foam that can have drywall screwed into it directly. Not sure if that is an option, though. In any event, I could put the framing back up if I needed to after putting the rigid foam in. Then I would have something to hang the drywall on.
I would rather use rigid foam than Roxul, because cleaning after previous owners' mice when the fiberglass batts were there was horrible, and because I'm paranoid about mice now, I think cleaning rigid foam would be easier, and it would be more mouse proof. However, part of the basement I will need to use Roxul anyway (the crawlspace), because the framing holds up the floor above it. I don't think it is possible to put rigid foam between the studs.
Old Yesterday, 08:15 PM   #12
Naildriver
chandler48's Avatar
Just so you are clear, you will not have any XPS to "clean" after you install it as it must be covered with a wall covering like sheetrock, paneling, etc. Roxul is waterproof, fireproof, mold proof and vermin proof, so mice won't eat any of it.
Larry......
Old Yesterday, 09:10 PM   #13
You can cut it to size and seal it to the studs with canned foam.
Yes, foam must be covered with something non-combustible.
For roxul keep in mind there's also the board - made from the same stuff but solid. It's a good substitute for foam in some applications.
Roxul in general is good stuff.
Old Yesterday, 11:30 PM   #14
Rewards Points: 44
I will keep the thread up to date with progress. This is still a couple of months down the road.
I really appreciate the help! Youtube videos tend to promote a single way of doing something, and miss all the nuances of what to do for the case-by-case scenarios of a real homeowner.
Old Today, 09:42 AM   #15
Rewards Points: 127
Nailed it, in my (inexpert, but studied) opinion.
I'm doing it this way: How to Insulate a Basement
Because my local HDs and Lowes' didn't have the tongue-and-groove insulation, I'm just making sure the seams are as tight as possible and I'll tape the insides of the seams with Tyvek™ tape. I'm applying expanding foam to any gaps along the bottoms.
The rim joists, which, in some places are doubled-up, were first "seam sealed" with Great Stuff. I placed 2" Foamular where there were single thickness' of rim joist, 1" Foamular over-all, then 1" of foil-backed foam over-all for fire code. The first layer of insulation was seam-sealed again. The 2nd and, in some cases, 3rd layers of insulation were fitted as snugly/precisely as possible.
Part of the my reasoning for going to all that trouble was not only to reduce radiated heat, and air and moisture incursion, but to reduce the heat signature outside to make the area less attractive to critters looking for warm places come fall. We've had rodent problems, ourselves, in the past. (I had found, in the process of gutting the room in question, that there had been a gap of 1/4" or more between the top of the basement wall and the bottom of the rim joist. I'm sure that had a lot to do with it.)
Btw: If you go with rigid foamboard insulation, and choose to use Loctite PL300 adhesive, don't believe what you read or see about its initial tack. It has all the initial tack of toothpaste. Unless the surface to which you're applying the foamboard is nearly ruler-flat: It won't stick worth diddly, initially, and it takes a full 24 hours to cure. So ways to keep the foamboard tight against the walls for that 24 hours is de rigueur.
(Note the clamps on the floor joists at the top, as well.)
prairiewind likes this.
More Power! is online now   Reply With Quote
