Insulating Attic Joists - Insulation - DIY Chatroom Home Improvement Forum
Like Tree3Likes
  • 2 Post By stick\shift
  • 1 Post By Nealtw
Old 04-24-2019, 10:21 PM   #1
Rewards Points: 26
insulating attic joists
I am converting an attic to a BR.
Its an older home where the ceiling joist spacing between joists is around 20" so 23" insulation would all need to be cut to fit.
Im thinking of laying 1" foam board on top of the ceiling joists for stability then rolling unfaced R30 on top of that. I could do loose fill but its only a 12x12 ceiling space probably not worth all the prep work for that.
My question is there any issue with the open space between the drywall and the foam board that would cause a vapor or mold issue. In other words the joist cavity would be uninsulated with the insulation above that space.
mtmprop is offline   Reply With Quote
Old 04-24-2019, 10:34 PM   #2
Rewards Points: 4,384
Re: insulating attic joists
The term 'ceiling joist' is confusing here - do you mean the joists in the floor of the attic/ceiling of the room below or the roof rafters/truss system?
Dave Sal and Bud9051 like this.
stick\shift is offline   Reply With Quote
Old 04-25-2019, 02:42 AM   #3
retired framer
Rewards Points: 4,830
There is much to talk about when you are insulating an attic bedroom so we will need a bunch more info about where you are and the venting you have and the stage you are at.
Bud9051 likes this.
Do not use flat bottom gables with scissor trusses.
Old 04-26-2019, 10:25 AM   #4
MarginallyQualified
TarheelTerp's Avatar
Rewards Points: 4,470
I'll jump ahead and say this plan will NOT happen.
As to insulating in an attic... blow in some cellulose or rockwool.
Old 04-26-2019, 12:57 PM   #5
Rewards Points: 923
I think I understand what you are wanting to do but please add more info so we can give you the right answers.
It sounds like you have an attic space where the roof is supported only with straight studs.
Are these roof supports what you are calling joists?
What is the dimension of these roof supports, 2x4, 2x6?
chiraldude is offline   Reply With Quote
Old 04-29-2019, 10:06 PM   #6
Rewards Points: 26
attic ceiling joists not floor joists.
these form the ceiling which ties the roof rafters together from outward stress.
Drywall is done, ceiling will need to be blow in now so my previous question is no longer needed to be answered.
thx for the responses.
Old 04-29-2019, 10:15 PM   #7
Rewards Points: 923
I hate to be a wet blanket but did make provision for an air gap between top of insulation and and roof deck? In other words, what will keep air flowing above the insulation to prevent condensation and mold?
Help with insulating split level attic james.young Insulation 1 07-12-2018 06:28 PM
Converting garage attic into light storage space lixepoc Building & Construction 7 01-05-2018 01:45 PM
Insulating attic pipes thew60 Insulation 4 01-10-2014 03:23 PM
2x6 joists for attic storage and ladder jobblyman Carpentry 9 09-28-2013 12:08 AM
Ideas on reinforcing attic joists PhaTea Building & Construction 22 12-07-2011 10:41 PM
