Insulating Attic With Flat Roof Under Sloped Roof - Insulation - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 1 Post By ryansdiydad
  • 1 Post By Gary in WA
Old 01-24-2017, 02:49 PM   #1
Rewards Points: 63
Insulating attic with flat roof under sloped roof
Been trying to figure out how to do this best for a while now and thought you all might have some suggestions.
I have a house that has a flat roof that was later covered by a sloped roof. Because of this, I have no access between the joists. I'm pretty sure the insulation between the ceiling and the flat roof is severely lacking so I'd like to add more. I believe the obvious solution is to just add fiberglass/cellulose over top of the flat roof. However, I've become accustomed to the easy of moving around in the attic because of the flat roof and use it for a lot of storage. I had the idea of screwing down 2" rigid foam board onto the flat roof, but wasn't sure about fire codes. Any other ideas?
syogod is offline   Reply With Quote
Old 01-24-2017, 07:13 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 944
Re: Insulating attic with flat roof under sloped roof
Is the sloped roof vented?
Rigid foam could work here and the code has evolved over time. Are there any utilities in the attic?
Will you be accessing it for storage on the regular?
Old 01-25-2017, 08:04 AM   #3
Rewards Points: 63
Yup.
No, only thing in there is a dryer vent and a furnace flue that come up through the flat roof and make a turn and go out through a gable.
Not daily or anything, but usually a few times a year.
Old 01-25-2017, 04:42 PM   #4
Registered User
Rewards Points: 526
So you have an impermeable full surface vapor barrier (the old glue-down material) with minimal insulation and no/any? venting -----and you want to put more insulation above this?
Gary
Old 01-25-2017, 06:43 PM   #5
Rewards Points: 1,528
I think OP said the sloped roof is vented. And yes clearly in his post he is saying he is trying to find a way to add insulation between the old and new roof..
Why not answer his question with a recommendation instead of just a condescending question back to him Gary? If you weren't intending to be condescending, then apologies but it sure looks like it to me.
OP clearly says he isn't sure how to tackle this which is why they came here.. Might be more helpful to tell him vs asking a question back that is basically just asking them to repeat what they already said in their first post...
Your question seems to imply that they should not do that.. So what should they do?
syogod likes this.
ryansdiydad is offline   Reply With Quote
Old 01-26-2017, 10:12 AM   #6
Rewards Points: 944
With a vented design, you should be just fine and the rigid foam will work just fine there.
I would check with local code enforcement on the thermal/ignition barrier requirements as different municipalities are using different versions and you want to make sure that you are all squared away and legal.
Depending on the climate and temps that you are dealing with, a foil faced foam might help with heat rejection and actually supply the thermal/ignition barrier requirements depending on code.
Be aware that as dust covers the foam, the radiant barrier effect is dramatically lessened and as Gary pointed out to me one time, you can actually create some ice damming issues as the eaves with foil faced foam if you aren't careful.
Old 01-26-2017, 11:46 AM   #7
Registered User
Rewards Points: 526
Thanks for the mention, WoW.
I added a sloped roof over a flat before. Be careful because the flat roof waterproof layer is also vapor proof. This will stop all moisture from below and unless you opened up the flat roof perimeters for more air flow under it, OTHERWISE you may have condensation there (if limited ventilation), depending on the ratio of R-value on each side of VB per climate; https://buildingscience.com/document...rchterm=attic+
If you don't have enough FB on top; https://buildingscience.com/document...3-over-roofing
Putting enough insulation on top to prevent condensation is tricky, due to the compressed state of the old insulation and amount of air flow to figure now that the soffit vents are supplying both roofs for ventilation. https://buildingscience.com/document...bout-diffusion
(1.) OR did you block the existing (in flat roof) lower fascia vents and add new ones between rafters?
(2.) Is there still an outlet/exhaust stack/vent in center of flat roof from before? With good air path under the flat roof you will not promote condensation BUT will deflate the R-value of any insulation put on top. It wouldn't be a "dead air" space that you could work with.
(3.) Did you cut any holes in the roof or it was damaged- breaking the air barrier?
(4.) Did you add baffles at the new soffit vents?
(5.) Are you open to the (optimum) option of cutting holes in every cavity for vapor escape and possibly air-sealing the ceiling/wall drywall joint, any plumbing/wiring holes) above all walls through rectangular access holes/slots over each wall below?
Sorry ryansdiydad, I was trying to help someone else get on track... won't happen again.
Gary
ryansdiydad likes this.
The Following User Says Thank You to Gary in WA For This Useful Post:
ryansdiydad (01-26-2017)
Insulating unvented flat roof charliefreak100 Insulation 5 09-22-2014 06:56 AM
RAISING A FLAT ROOF TO A SLOPED ROOF + Heat+great room reno Ilovemyhouse? Building & Construction 2 01-25-2014 08:46 AM
gently sloped flat roof shed b_corwin Roofing/Siding 3 05-14-2010 04:40 PM
Flat roof repair/replacement questions zmt Roofing/Siding 4 02-23-2010 11:24 AM
How to design and build attic closet over sloped roof Mendosherman Building & Construction 5 07-09-2009 02:15 PM
