Insulating Above Ground Dry Stone Foundation - Insulation - DIY Chatroom Home Improvement Forum
Old 10-19-2015, 02:18 PM   #1
Rewards Points: 12
Insulating above ground dry stone foundation
I recently purchased an older home, and it has a dry stone foundation. the front part of the foundation is above the ground by a couple of feet. there is a wooden sheathing board that covers up the stone foundation but behind that there is a space with no insulation at all. just the exterior of the foundation.
I was wondering the best method of insulating this sp0t and if i should put some hydraulic cement in there. i live in a relatively cold area, -30 for a couple weeks each year. lots of snow and it gets to about 95 or so at max in summer.
Thank you for your input.
Lockehaven is offline   Reply With Quote
Old 10-19-2015, 02:42 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 906
How is the wood affixed to the stone?
If the space can be air sealed and made air tight, insulating the wood might be preferred.
Dry pack stone foundations are very sensitive and whatever way you go, you might want to preserve an inspection area for the service and maintenancef of the foundation.
Old 10-19-2015, 03:16 PM   #3
Rewards Points: 12
the sheathing isn't attached to the foundation at all just hangs from the sill. about 8 inches of space and the bottom of the sheathing meets the ground.
Old 10-19-2015, 03:43 PM   #4
Rewards Points: 12
My thought was to sue some hydraulic cement and then cover it with blue board.
Leaking basement with stone foundation SAS66 Concrete, Stone & Masonry 17 09-22-2015 02:53 PM
Field stone foundation - French drain alperin Building & Construction 6 01-05-2015 11:41 AM
Ground wire from panel to ground rod swbrains Electrical 46 09-03-2014 05:05 AM
Old stone foundation and no footers Wayne Perry Concrete, Stone & Masonry 7 10-07-2012 08:13 AM
50 Amps for a garage help IcyShadowz Electrical 48 05-31-2012 10:58 PM
