Insulate Floor Of 3 Seasons Room - Insulation - Page 2 - DIY Chatroom Home Improvement Forum
Like Tree9Likes
Old 11-05-2019, 08:07 AM   #16
retired framer
Rewards Points: 306
Re: Insulate Floor of 3 Seasons Room
Originally Posted by TimRemo View Post
I have the same mindset as you. Fiberglass will run me about $70 right now on sale. Iíll face it down and add some wire or mesh and see what happens. Thanks!
If paper faced is all you can get put the paper up. Rock wool handles moisture better.
Do not use flat bottom gables with scissor trusses.
https://www.fema.gov/media-library-d...6/chapter7.pdf
figure 7-14
The Following User Says Thank You to Nealtw For This Useful Post:
TimRemo (11-05-2019)
Old 11-05-2019, 09:25 AM   #17
Rewards Points: 102
I have the same mindset as you. Fiberglass will run me about $70 right now on sale. I’ll face it down and add some wire or mesh and see what happens. Thanks!
But wouldn’t the paper face the ground to block any moisture from hitting the fiberglass? Or am I thinking about that incorrectly? I always thought there should be a barrier of some sort between the ground and fiberglass.
TimRemo is offline   Reply With Quote
Old 11-05-2019, 11:18 AM   #18
retired framer
Rewards Points: 306
But wouldnít the paper face the ground to block any moisture from hitting the fiberglass? Or am I thinking about that incorrectly? I always thought there should be a barrier of some sort between the ground and fiberglass.
It is just an upside down attic.
TimRemo likes this.
figure 7-14
Old 11-05-2019, 02:28 PM   #19
JUSTA MEMBER
Rewards Points: 70
If the paper is exposed to atmosphere, it will absorb moisture from the humidity, and fail sooner than you think.
I would get paperless and cover with plastic sheet, then add a plywood cover to stop those critters.
But I am an OCD about things at times.
ED
de-nagorg is online now   Reply With Quote
Old 11-05-2019, 08:49 PM   #20
Rewards Points: 102
Alright. Thanks everyone for all the input. It such a simple idea, insulate a floor, yet so many tiny things to consider sometimes.
de-nagorg likes this.
