Insulate Exterior Of Old Brick Home - Insulation - DIY Chatroom Home Improvement Forum
Old 06-25-2014, 08:56 PM   #1
Insulate exterior of old brick home
I have a 95 year old brick home and the brick is two layers thick. In most rooms, the interior lathe and plaster is laid directly on the brick. The exterior already has a layer of stuuco put on, which doesn't look very good and is cracking and peeling in many places. I'd like to insulate the exterior of the house with rigid foam board and then restucco. I do not think I'd do this myself, but through a contractor. I'd like to be an educated buyer, but I can't find much information about how to attach the foam board to the exterior. I'm guessing it would be glued on. Also there's a lot of details that I wonder about such as how to make corners, what to do around doors and windows and at the meeting points of wall with ground and wall with roof. I also haven't done any stucco work before, so I'm not sure what I should be looking for in a good contractor for either aspect of this job.
If you have experience with this or references you can share with me, I would appreciate it! Most exterior foam board insulation projects I've seen articles about so far are with sided homes or new construction, not attaching to brick. Thanks.
Spiderzak is offline   Reply With Quote
Old 06-26-2014, 04:55 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 944
The exterior foam can be glue but it will most certainly be mechanically attached as well.
This is going to be and expensive undertaking and should be done 100% correct.
I would also like to see some sort of drainage plane to allow the home to dry to outside as well as keep any condensation issues at bay.
Tags
brick , exterior , foam board , glue , insulate
Need URGENT help with question regarding fixing electrical panel in home asledge Electrical 66 02-22-2013 04:49 PM
1.5 Story Home with Dormer Windows - Insulate Rafters? hartkem Building & Construction 2 11-11-2011 09:40 PM
Started Exposed Brick Wall, Studs within brick, should I stop? perry167 Building & Construction 4 01-05-2011 09:41 AM
Brick Home - brick fronts cracking off AndrewF Building & Construction 2 09-10-2009 04:48 PM
Attaching Deck to Brick Home stubits Building & Construction 1 08-12-2009 11:54 AM
