Installing Foam Board Around Basement Windows - Insulation - DIY Chatroom Home Improvement Forum
Old 11-08-2015, 03:08 PM   #1
Rewards Points: 2
installing foam board around basement windows
Basement is fully insulated except around the inside of the basement windows. Noticed some condensation on the concrete and wonder if using some adhesive to attach some xps foam board. And then using tuck tape to prevent any of the warm basement air from reaching the concrete would create any problems.
jdsooner is offline   Reply With Quote
Old 11-08-2015, 03:40 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 848
Originally Posted by jdsooner
Basement is fully insulated except around the inside of the basement windows. Noticed some condensation on the concrete and wonder if using some adhesive to attach some xps foam board. And then using tuck tape to prevent any of the warm basement air from reaching the concrete would create any problems. Thanks
It should work just fine, but keep in mind that you should not be leaving exposed foams without some sort of ignition or thermal barrier.
Installing deck ledger board over foam board? RickT Building & Construction 9 04-27-2018 11:41 AM
How to - prevent basement mold crazymountain How To Guides 36 07-23-2014 06:02 PM
Why not remove kneewall batting and replace with foam board? fdecker Building & Construction 1 10-20-2010 04:46 PM
installing high basement windows denemante Building & Construction 3 08-27-2010 04:18 PM
Foam Board on exterior of above grade house Sheldon General DIY Discussions 6 12-08-2009 04:05 PM
