Improving Attic Insulation - Mansard Roof - Insulation - DIY Chatroom Home Improvement Forum
Old 11-28-2014, 08:49 PM   #1
DIYer
Rewards Points: 249
Improving attic insulation - mansard roof
Hi guys,
I am trying to improve the insulation in my attic. I live in Montreal, Canada our winters are very cold.
Currently the attic has 6 inches of fiberglass batts with some blown fiberglass over it and it doesn't look like they added enough.
I believe in my area they recommend a minimum of R50 for attics.
My mansard roof has a continuous soffit vent all around that was added later on, other homes in my neighborhood don't have it.
The air chutes are 2 feet long and made from plywood most likely by the contractor who added the soffit vent.
My plan is to suck out the blown fiberglass and add cellulose on top of it after sealing the top plates, electrical boxes and plumbing stack.
Do I need to extend the chutes to 4 feet before I add the insulation?
Thanks.
VitoB is offline   Reply With Quote
Old 11-28-2014, 10:20 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 926
You will need to extend them far enough to where they won't be blocked by the R-50.
Old 12-01-2014, 10:30 AM   #3
DIYer
Rewards Points: 249
Appreciate the advice.
Should I leave the fiberglass batts in there? Or is not worth the trouble of removing them?
My only concern with leaving them in is the knee walls. Ideally I would have liked to spray foam them first and then blow the cellulose on top of that.
Old 12-01-2014, 01:49 PM   #4
Rewards Points: 926
Blow over the top is fine.
Kneewalls work well when you cover the entirety of the framing with rigid foam and seal all the gaps.
Old 12-06-2014, 03:30 PM   #5
Rewards Points: 6
Excellent resource on building insulation
I can recommend an excellent book that not only covers interior building insulation but all aspects of building energy efficiency. It is called: "The Visual Handbook of Energy Conservation: A Comprehensive Guide to Reducing Energy Use at Home" by Charlie Wing. I cannot recommend this book highly enough for anyone looking to improve the efficiency of their building. It is literally packed with graphics, charts, and plain language explanations of how and why building insulation works
tekart is offline   Reply With Quote
Attic Insulation with a new roof indigo Insulation 11 03-18-2014 11:22 PM
Attic insulation ideas/help drgnflys Insulation 14 03-23-2013 05:10 PM
Attic Ventillation Problem. Why Now? Hubs Roofing/Siding 2 03-19-2013 10:23 AM
Can/should I add insulation underneath stationary stairs to my attic? Bitruder Insulation 3 12-28-2012 11:04 PM
Attic insulation bids and soffit vents-need input nolamar Insulation 7 05-14-2011 10:04 PM
