How To Kill Mold - Insulation - DIY Chatroom Home Improvement Forum
Like Tree6Likes
Old 01-12-2019, 02:49 PM   #1
Rewards Points: 64
How to kill mold
I recently had a leaking on my roof that has been fixed. I am in the process of replacing the drywall and insulation. After taking out the old drywall and insulation I see a couple area with green mold.
Can I use white vinegar and baking soda with spray bottle to kill the mold?
Can I also use this?
Rust-Oleum 276087 Mold Killing Primer Quart https://www.amazon.com/dp/B00K7FEQPI..._qkLoCbH0XV03Y
dws780 is offline   Reply With Quote
Old 01-12-2019, 03:47 PM   #2
Big Dog
Drachenfire's Avatar
Rewards Points: 5,132
Re: How to kill mold
While you can certainly use the primer, I recommend you clean the area first regardless.
Pre-clean the surfaces of any visible material.
Make a solution of 3/4 cup bleach per gallon of warm water in a bucket.
Wearing safety glasses and rubber gloves, apply to the affected area with a sponge or brush.
Allow it to sit in contact with the mildew for 5 minutes, then rinse with warm water. Allow to air dry thoroughly .
You may need another application if the problem is severe.
Be sure to ventilate the area as much as possible to promote drying and evacuate fumes.
In all probability, some of the solution will drip on you so make sure the clothes you wear are either white or ones you do not care if they get stained.
You can also use a pre-made mold and mildew cleaner found in the bathroom cleaning products section of your local supermarket.
Dave Sal and Bud9051 like this.
My Deck Rebuild Progress
Fate whispers to the warrior, "You cannot withstand the storm," and the warrior whispers back, "I am the storm."
Drachenfire is offline   Reply With Quote
Old 01-12-2019, 03:49 PM   #3
Super Moderator
Gymschu's Avatar
Rewards Points: 606
Concrobium. Wal-Mart and all the big box stores carry it.
Yodaman and BayouRunner like this.
"In the heat of battle, my father wove a tapestry of obscenity........."
Old 01-12-2019, 03:53 PM   #4
retired framer
Rewards Points: 662
Home depot has a video on killing and clean mold.
https://www.homedepot.com/c/ah/how-t...5fab907c52351c
Once the moisture is gone the mold goes dormant. Engineers are always more worried about rot that needs much less moisture to survive, they always want the stained areas coated with the end cut treatment for treated lumber, It paints like water.
Old 01-12-2019, 04:39 PM   #5
Rewards Points: 64
Lol I was just at Home Depot and picked this up. I will use it tomorrow. Thanks
Gymschu likes this.
Old 01-12-2019, 04:50 PM   #6
Rewards Points: 64
I got the mold control from Home Depot. Will give that a try tomorrow and see how it works.
Old 01-12-2019, 05:25 PM   #7
Rewards Points: 166
My only objection to the Concrobium is that it doesn't change the appearance where you are cleaning, at least didn't for me. I went back to the bleach approach as Df described and the stain faded away. The irony is, mold is everywhere all of the time just waiting for some moisture to get it going. Since you have the Concrobium it will do just fine as it will kill what is there.
Bud
Drachenfire likes this.
I volunteer my help and opinions, but you are responsible for what YOU choose to do with that information.
Bud9051 is offline   Reply With Quote
Old 01-13-2019, 08:03 AM   #8
Big Dog
Good luck.
Old 01-13-2019, 02:08 PM   #9
Rewards Points: 64
Old 01-13-2019, 02:09 PM   #10
Rewards Points: 64
Old 01-13-2019, 02:11 PM   #11
Rewards Points: 64
After a couple of sprays
Looks goods I will wait until fully dry tomorrow and spray a few more then paint it with that mold primer
Old 01-13-2019, 04:09 PM   #12
Rewards Points: 166
Is there any airflow for ventilation above that insulation. Needs inlet (low) and exhaust (high) and a couple of inches of space above the insulation (minimum 1").
Bud
Old 01-13-2019, 05:16 PM   #13
Rewards Points: 64
Bud
No thatís all there is. The insulation is not a very snug fit I say probably like 1/4 - 1/2Ē play on it.
Old 01-13-2019, 07:17 PM   #14
Rewards Points: 166
Your choice, but best practices and in some places a code requirement is to have a gap and ventilation. There are no recommendations for having air permeable insulation directly against a cold roof deck. I suspect some of the discoloration we are seeing is moisture damage from condensation.
Bud
Old 01-13-2019, 07:22 PM   #15
Rewards Points: 64
Bud
Thatís from a leaking roof.
Re-SIDING found MOLD from condensation Glanz Roofing/Siding 7 11-16-2016 09:30 AM
Mold in Wall from prior leak crayola110 Drywall & Plaster 17 11-02-2012 05:37 PM
Mold problem after unfinished house was closed in for the winter... lemonbltz Building & Construction 28 12-30-2011 07:52 PM
Concrobium or White Vinegar? eis61374 Remodeling 8 11-17-2008 06:56 AM
How important is plastic vapor barrier on foundation wall? slatergrl Remodeling 5 02-18-2008 12:49 PM
