How To Insulate An Un-finished Attic And Prevent Ice-Dams In A 1920s 2-family MA Home - Insulation - DIY Chatroom Home Improvement Forum
Old 03-22-2018, 11:23 AM   #1
vr4
Rewards Points: 12
Question
How to Insulate an un-finished attic and prevent Ice-Dams in a 1920s 2-family MA Home
Hi everyone!
I have a 1920s home with an unfinished attic here in snowey Massachusetts. The attic ceiling is un-insulated, with exposed rafters and an asphalt tile roof. I was warned about ice-dams and how improper insulation will lead to a destroyed roof. The attic space is currently openly vented through two vents one at each end of the attic. The problem is I have no idea how to prevent ice-dams -- this is something new to me.
With the wisdom of the community, how can I set up my insulation propperly to prevent icedams?
  1. Is spray on closed-cell foam my best bet?
  2. Do i need to cut soffit into the attic roofline? Is there something else I should do
  3. Any other tips or tricks?
Thank you everyone in advance for the input!
vr4 is offline   Reply With Quote
Old 03-22-2018, 11:24 AM   #2
vr4
Rewards Points: 12
Re: How to Insulate an un-finished attic and prevent Ice-Dams in a 1920s 2-family MA
Old 03-23-2018, 11:10 AM   #3
vr4
Rewards Points: 12
Appreciate in advance the input.
Old 03-23-2018, 11:19 AM   #4
retired framer
Rewards Points: 606
Ice dams are caused by heat leaking from the top of the wall warming the insulation and the roof right there. Soffet vents to an air gap between the insulation and the roof sheeting will allow air in but it has to have a way out to. box vents or ridge vents for that.
Old 03-23-2018, 11:41 AM   #5
Residential Designer
AndyGump's Avatar
Rewards Points: 882
Send a message via Skype™ to AndyGump
What is it that you are trying to accomplish, in an overall sense?
Just more insulation for energy savings or do you want to use the attic as new living space sometime?
Andy.
Residential Drafter/Designer
www.draftinginoc.com
AndyGump is offline   Reply With Quote
Old 03-23-2018, 11:49 AM   #6
Rewards Points: 166
Difficult question. I've been a few of those old attics up here in Maine and they don't always have the problems one might expect.
One disadvantage is we/you don't know exactly how the current roof is performing, or do you, first hand I mean?
With the floor covered as we see in the picture it tells me you don't have enough insulation in the attic floor and you don't have access to increase it and do the proper air sealing. I looked up the 09 energy codes for MA and they show R-38 for the ceiling. That may have increased depending upon which generation of codes your local authority is following. But at R-38 you would need about 11 inches of insulation and you wouldn't want the flooring over the top of it, a condensation issue.
Sounds like you would also want more ventilation.
Then there is the unvented attic approach, but that has its challenges as well.
Let's see what ideas others have.
Bud
Bud9051 is online now   Reply With Quote
Old 03-25-2018, 01:14 PM   #7
user_12345a's Avatar
Rewards Points: 56
Air sealing is more important than insulation, if you have a lot of air leaking from the house, the insulation won't do it's job.
I see two potential options:
1. Remove the floor boards, remove existing insulation, air seal or better yet have a thin layer of foam sprayed to create a full thermal break.
Install baffles to not block the soffits vents, blow insulation over top to R50.
Install roof vents
2. Leave existing insulation and floor boards intact.
Close the soffit vents off, spray foam the roof deck.
My reservation about this option is that your roof deck boards don't appear to be in good shape; they have large gaps. When the roof is re-done, foam adhered to tar paper or whatever that black stuff is could come off as they remove shingles.
I am not in the business of any trade I give advice on. I have non-professional hvac experience + good knowledge of theory. Attempt repairs at your own risk. Never jump out safeties - especially pressure switches - on a furnace for testing with fuel supply on; use a meter. Do not troubleshoot with live line voltage present unless there's no alternative.
user_12345a is online now   Reply With Quote
Old 03-26-2018, 03:39 PM   #8
vr4
Rewards Points: 12
Really appreciate everyone's input. I should have included more info in the original post!
We are trying to add two bedrooms and a bathroom to the [currently] un-finished attic space.
Bud
The roof was re-done in 2015 -- new 30-year asphalt shingles etc. No leaks or evidence of leaks.
So it sounds like we should take up the current floor boards to re-insulate the ceiling. And then we should use spray on foam for the attic. Thoughts on this?
Old 03-26-2018, 03:43 PM   #9
vr4
Rewards Points: 12
This is great input. I am leaning towards option #2. it is possible I do not know what the word "soffit" means, but to my understanding, I do not have any soffit vents?
Old 03-26-2018, 04:09 PM   #10
Property Mgt/Maint
Rewards Points: 24
Extremely important detail. What you will essentially be doing is creating short sections of cathedral ceilings. With your existing (looks like 2 x 6) rafters the depth is too shallow for a air space and fiberglass. Research cathedral ceilings and knee wall insulation. You are going to want a good ridge vent all the across and also a continuous low intake vent. If no soffits there are some other ways to get it done. A pic or two from the out side would help.
Yodaman is offline   Reply With Quote
Old 03-28-2018, 01:12 PM   #11
Rewards Points: 56
Cathedral ceiling = good candidate for foam. Roofing material tends to be non-permeable so there's no drying potential. (which may be why they still try to ventilate cathedral ceilings)
Foam is a complete thermal and moisture break.
This is soffit vent:
It's needed to allow fresh air in from outside to replace the air expelled by roof vents.
Tags
attic insulation , attic insulation ice dams , closed cell foam , ice dam , sofit
Ridge vent vs mushroom fan gtothek Roofing/Siding 8 03-30-2015 02:12 PM
Insulating your attic Bob Mariani How To Guides 5 07-07-2013 08:49 PM
Newbie questions on refinishing walkup attic with knee walls FileOpen Insulation 2 11-19-2011 11:31 PM
Are you ready for SNOW & ICE ? Roofmaster417 Roofing/Siding 15 10-09-2011 09:25 AM
