How To Insulate Floor - Insulation - DIY Chatroom Home Improvement Forum
Like Tree3Likes
  • 1 Post By Windows on Wash
Old 07-12-2020, 03:33 PM   #1
Rewards Points: 8
how to insulate floor
My house was built in 1918 and i am wanting to insulate the floors from the crawl space. the joists are 2x10 and the crawl space is only about 2 feet so not a lot of room to work. doesn't look like there has ever been a water problem so what kind of insulation is best? Do I use open faced or paper backed? there is only 2 vents for the crawl space but no mold or rot present. Thank you.
1redneck is offline   Reply With Quote
Old 07-12-2020, 04:56 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 906
Re: how to insulate floor
Where is the home? Ductwork or plumbing in the crawl?
Bud9051 likes this.
Old 07-13-2020, 11:34 AM   #3
Rewards Points: 8
N.E Missouri. No plumbing or duct work in the way.
Old 07-13-2020, 01:48 PM   #4
Rewards Points: 906
In that case, clad the underside with foil faced foam. Tape and air seal the seams. I would still insulate and air seal the bandjoists as well as put some insulation toward the earth sides of the joists.
https://www.buildingscience.com/docu...in-crawlspaces
SPS-1 likes this.
Old 07-13-2020, 04:54 PM   #5
Rewards Points: 8
Thank you. Will do.
Old 07-13-2020, 10:31 PM   #6
Missouri Bound's Avatar
Rewards Points: 4,188
Not sure what you mean by foil faced foam. Are you talking polyiso?
Do you want it your way or the right way?
Missouri Bound is online now   Reply With Quote
Old 07-14-2020, 06:50 AM   #7
Rewards Points: 906
Yes. But there are other foil faced foam. Something that will be resistant to any moisture degradation.
Old 07-14-2020, 01:47 PM   #8
I was just thinking how hard it may be to install 4 X 8 sheets in such a tight area, let alone getting them in there.
Old 07-14-2020, 03:07 PM   #9
Rewards Points: 2
Ours is similar to yours. We did the spray foam about 3 years ago. I am really happy with the results. Although itís not really diy or inexpensive
BayouRunner is offline   Reply With Quote
Old 07-14-2020, 04:03 PM   #10
Rewards Points: 906
If its tight, the work is not for the faint of heart. Definitely something that I would prefer to pay someone for.
SPS-1 likes this.
