How To Insulate Around Chimney Chase In Attic? - Insulation - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By Yodaman
Old 10-30-2019, 09:19 AM   #1
Rewards Points: 8
how to insulate around chimney chase in attic?
How should I insulate around this chimney chase in my attic. It doesn't have a very large opening and would be hard to get metal around the flue. Is sealing it off from the attic good enough?
Also this is next to the chimney chase.
Thanks for the help!
Jim
bignosejim is offline   Reply With Quote
Old 10-30-2019, 09:55 AM   #2
Rewards Points: 20
Re: how to insulate around chimney chase in attic?
In the house, I used a sheet metal dam around the insulated pipe.
In the garage, I made a dam around the insulated pipe. I do not remember if I used sheet metal or sheet rock or plywood.
After making the dam, I did scoop the insulation that had fallen against the insulated pipe.
fireguy is offline   Reply With Quote
Old 10-30-2019, 12:06 PM   #3
Rewards Points: 8
So, would I be okay with sealing off the chimney chase from the attic with a board and orange spray foam?
Old 10-30-2019, 12:48 PM   #4
retired framer
Rewards Points: 866
Hook up a selfy stick and get a picture looking down in there, Our chases are insulated and drywalled including a ceiling, It's a catch 22 you want the heat to move out of the chase but you want more insulation on the ceiling right there. I would add an Air chute and block below that with a chunk of bat insulation to hold back the loose insulation.
Do not use flat bottom gables with scissor trusses.
https://www.fema.gov/media-library-d...6/chapter7.pdf
figure 7-14
Nealtw is offline   Reply With Quote
Old 10-30-2019, 04:31 PM   #5
Rewards Points: 8
Here are some pics looking inside the chimney.
Looking up
and looking down
There is a bedroom on the other side of the wall behind the insulation.
Old 10-30-2019, 04:45 PM   #6
retired framer
Rewards Points: 866
Looking up
and looking down
So it can vent to the outside I would just full the void s with bat insulation and call it a day.
figure 7-14
Old 10-30-2019, 06:23 PM   #7
Property Mgt/Maint
Rewards Points: 26
What appliance is using the chimney? How hot does it get? That really determines what should or shouldn't be in contact.
Do not allow cool moist air from a cellar/basement to move freely into the attic space. That is a surefire way to create mold in the attic.
Windows on Wash likes this.
[political signature removed]
Yodaman is offline   Reply With Quote
Old 10-30-2019, 07:57 PM   #8
Rewards Points: 8
It goes to a natural gas fireplace in my living room. We only use it when it gets cold.
Old 10-31-2019, 05:35 AM   #9
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 944
Looks like they made it super easy (sarcasm) for you to get out there. A bit of Roxul in that chase at the top and bottom to try and slow down the air movement would help warm it up a good bit.
