How To Fill The Gap Between Framing And Tar Paper - Insulation - DIY Chatroom Home Improvement Forum
Old 06-25-2015, 11:01 AM   #1
Rewards Points: 28
Question
How to fill the gap between framing and Tar paper
Hello,
The attached picture is a piece of cardboard slid down between the exterior wood framing and the tar paper. This gap is say 1/16-1/8 of an inch along that the wall. The cardboard slides down about 6-8 inches.
The question is should I fill this with some spray insulation from a can over the surfaces of the 2x4 and Tar paper, or from under the house. The house is on a raised wood foundation. Is seems like it may not stick to the paper. I just don't know. Any ideas or experience with this problem is appreciated.
Thanks,
Jay
Jwhitman is offline   Reply With Quote
Old 06-25-2015, 12:24 PM   #2
craig11152's Avatar
Rewards Points: 1,220
I'm not sure what I'm looking at. Is that whole space going to get insulated?
craig11152 is offline   Reply With Quote
Old 06-25-2015, 01:14 PM   #3
Rewards Points: 144
I'm not sure what I'm looking at either but having a hard time figuring out why you think that cardboard needs to be there.Take the cardboard out and forget about it.
What are you trying to do with this wall?Insulate?Finish?Nothing?
mako1 is offline   Reply With Quote
Old 06-25-2015, 01:53 PM   #4
craig11152's Avatar
whats on the other side of the tar paper?
Old 06-25-2015, 05:27 PM   #5
Registered User
Rewards Points: 526
Turn your head 90* to view (bottom plate gap to exterior wall building paper, no sheathing). Leave the gap as the paper is not air tight at the laps/seams (horizontally every 3') anyway. You could air-seal the wood decking from under the house to stop crawl-space air movement to there.
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
craig11152 (06-26-2015)
Old 06-25-2015, 08:34 PM   #6
Rewards Points: 28
Thanks for the ideas. I think I will seal it from under the house. Sorry the picture was not clear, with the cardboard. Thanks for the replies
Jay
