Hold In Siding Where Aluminum Siding And Flat Roof Meet - Insulation - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By DeeEyeWhy
Old 10-29-2018, 01:19 PM   #1
Rewards Points: 234
Hold in siding where aluminum siding and flat roof meet
I have a hole in my outside wall where the aluminum siding meets my first floor flat roof. I found it today when I took off the window moulding as I can see the sunshine coming right through the wall. it appears that the aluminum siding curled upwards allowing for the space. i am unsure how the hole got there, maybe a rodent, but I need to close the gaps under the aluminum siding so nothing else gets in there including air. Any ideas on what i should use?
The hole is situated between two studs that are about a quarter inch apart so its too small to fit pink insulation in there but big enough for all the air to come in.
The hole is located such that i cant get a picture of the actual hole so sorry for not showing my situation.
I thought about filling the hole with the gap filler foam from the outside under the aluminum but i am not sure if that's the correct route to go.
Thanks in advance
DeeEyeWhy is offline   Reply With Quote
Old 10-29-2018, 04:03 PM   #2
JUSTA MEMBER
Rewards Points: 182
Re: Hold in siding where aluminum siding and flat roof meet
Minimal expansion foam in a can, would be my choice.
Great Stuff.
ED
de-nagorg is offline   Reply With Quote
Old 10-29-2018, 04:07 PM   #3
Rewards Points: 234
Great Stuff.
ED
thanks but i thought that was flammable and couldn't the exposed? I guess i was thinking of something that is waterproof and can be used on the exterior but if this stuff is good i have a can of it already.
Old 10-29-2018, 04:32 PM   #4
JUSTA MEMBER
Rewards Points: 182
The label will say if it is, So if what you have is, then seek some that is exposable, and fire retardant.
They make, it for fireplaces, so some of it must be retardant.
ED
Old 10-29-2018, 05:12 PM   #5
Rewards Points: 234
ED
my can said interior and exterior so I guess it is ok. it said it cant be used in enclosed crevices which this is not so it should be fine I suppose.
de-nagorg likes this.
Old 11-14-2018, 11:32 AM   #6
Rewards Points: 18
fire-rated will be orange, at least in U.S.
Seattle2k0 is offline   Reply With Quote
Replacment of a flat roof ih8lag Roofing/Siding 3 06-20-2018 04:36 PM
Roof to Wall Flashing Installation Painted Cedar Lap Board Siding Deeppool Roofing/Siding 3 12-08-2010 07:36 AM
Install a deck on top of a EPDM flat roof. -Pjackso Roofing/Siding 16 08-02-2010 03:35 PM
Roof and siding damage sando777 Roofing/Siding 6 07-29-2008 08:41 AM
