High Electric Bills, Need To Insulate - Insulation - DIY Chatroom Home Improvement Forum
Old 08-29-2015, 02:49 PM   #1
Rewards Points: 18
High electric bills, need to insulate
Hi to all, first time posting but i've been doing a lot of reading on this board trying to learn. i need some help with insulation in my house, it's a single level built in 1967 with brand new HVAC system but my last power bill was 500.00 and i need to do something. i'm attaching picture of my attic, no it is not vented in anyway. any advice would be helpfull, not sure of what more info you need but i'll answer anything i can.
R,
Trevor
High electric bills, need to insulate-img_20150829_095618782.jpg   High electric bills, need to insulate-img_20150829_095631550.jpg   High electric bills, need to insulate-img_20150829_095658342.jpg   High electric bills, need to insulate-img_20150829_095706146.jpg
da_offroadnut is offline   Reply With Quote
Old 08-29-2015, 04:27 PM   #2
Rewards Points: 5,348
How expensive is electricity in San Diego?
What do you set the A/C at?
Do you use the whole house fan?
How long have you owned the house?
Temps in San Diego have been in the upper 70's with about 10 days in the 80's this month.
Is the dryer electric?
Venting the attic will help as well as proper insulation.
Is that white vent hose from the bathroom/kitchen. That should be vented to the exterior.
Ron
B. Franklin 1759
The Following 2 Users Say Thank You to Ron6519 For This Useful Post:
craig11152 (08-29-2015), Hick (08-29-2015)
Old 08-29-2015, 04:34 PM   #3
craig11152's Avatar
Rewards Points: 1,220
I assume a chunk of that 500 bucks was running AC?
besides reducing the bill do they have averaged year around payment plans?
I'm in Michigan where winter heat is the bigger issue. I pay the same amount every month year around for my gas. Once a year I square up and then get a new rate depending on my use. In your case you could mitigate the big summer bills by paying more in the winter.
Don't look at me. I didn't vote for either one of them.
craig11152 is offline   Reply With Quote
Old 08-29-2015, 04:56 PM   #4
Rewards Points: 750
Is the stove electric?
Do you leave the lights on? are those lights incandescent/florescent/led?
Size of TV/usage?
What eles zapps your electricity?
What was average electrical bill before you installed hvac?
As ron mentioned, all those questions need to be answered/addressed.
Best/quickest solution I see is blown-in insulation.
Hick is offline   Reply With Quote
Old 08-29-2015, 05:07 PM   #5
Oso954's Avatar
Rewards Points: 68
The temps given on most sites are taken fairly close to the harbor/ocean. If you are in eastern San Diego they can be 15-20 degrees higher.
Oso954 is online now   Reply With Quote
Old 08-29-2015, 11:31 PM   #6
Rewards Points: 18
I've owned the house for a few years, temps passed month have been mid to high 90's with the occasional hit above 100. I set the temp to 78 but today the house was 84 inside. Everything is electric except for water heater and furnace. I have all florescent lights, been slowly swapping them to LEDs. We don't keep much lights on in the house, the whole house fan is disconnected, had to because I need space in the breaker panel for the ac unit. The white duct is for one bathroom vent which I'm fixing as soon as it cools down a little. I want to switch to a gas dryer but I have no room in my panel for a new circuit to run it, the gas line is there though. Can I run the dryer and washer on the same 20 amp circuit?
Old 08-29-2015, 11:43 PM   #7
An old Tradesmen
Rewards Points: 122
You remove the current breaker for the dryer. And then you will have 2 spaces open. And can use one of them for the gas dryer.
The Following User Says Thank You to beenthere For This Useful Post:
craig11152 (08-30-2015)
Old 08-30-2015, 07:05 AM   #8
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 944
$500 in San Diego is a bit crazy with the mildness of weather.
http://www.climate-zone.com/climate/...nia/san-diego/
http://apps1.eere.energy.gov/buildin...ing_report.pdf
Old 08-30-2015, 07:22 AM   #9
Rewards Points: 877
If it was my house I would start with two things. Improve attic venting and add blown in insulation which you can do yourself. I would research attic venting options looking at soffit vents, depending on roof type possibly a ridge vent. You can rent equipment from Lowes, HD to blow in insulation and get advice on how to do it.
ddsrph is offline   Reply With Quote
Old 08-30-2015, 09:09 AM   #10
Rewards Points: 18
i'm looking at different options if i remove the electric dryer and go gas, unfortunately if i do i do not get to free up the circuit, i use it for my plasma cutter with my air compressor on the other 30 amp circuit and well the way it is wired ill need a new post in the electric fofum here.. the biggest thing i know is attic venting and better insulation. the attic is not not vented, soffits have no venting, the outside walls a stucco so i'm trying to figure out what to use for soffit vents as my soffits do not look like any house i've seen.
Old 08-30-2015, 06:53 PM   #11
Oso954's Avatar
Rewards Points: 68
You have that gable end vent and fan. Are you saying there is no gable vent at the other end?
Makes you wonder what they were thinking ?
Hope you aren't running it. Right now it would be pulling your conditioned air up thru the bathroom vent and any other leak spots.
Electric Bill Way Too High, Corrupt Electric Co HELP! RStephen Electrical 18 02-26-2013 01:09 PM
outrageous electric bills creeper Off Topic 1 03-16-2012 09:21 PM
Electric Baseboard Heater Questions mark2741 HVAC 0 12-31-2010 12:08 PM
90 amp electric car charger! The future... Billy_Bob Electrical 16 02-16-2010 02:01 PM
electric usage rocksaranac Electrical 6 08-12-2009 12:41 PM
