Help With Sensor Insulation - Insulation - DIY Chatroom Home Improvement Forum
Old 01-10-2018, 05:01 AM   #1
Rewards Points: 4
Lightbulb
Help with sensor insulation
Hello guys! They've installed some digital meters on radiant heaters in my flat last week and I'm trying to figure out if its possible to insulate it without using montage foams etc. to reduce the amount of tracked heat. The meter has been attached with screw and nut. (see picture) Thanks for any suggestions!
Floydo is offline   Reply With Quote
Old 01-10-2018, 05:07 AM   #2
Naildriver
chandler48's Avatar
Rewards Points: 324
Re: Help with sensor insulation
Are you trying to get around your responsibility of paying for your heat? No help here, if that is the case. That unit uses the probe to detect heat, so it would be almost impossible to isolate it from the source.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
The Following User Says Thank You to chandler48 For This Useful Post:
Floydo (01-10-2018)
Old 01-10-2018, 05:16 AM   #3
Rewards Points: 4
Yeah you busted me! But thanks for dealing straightly with me. Have a nice day.
Tags
insulation , lifehack , radiant heating
