Had Vents Installed In Attic Due To Peeling Celing - Insulation - DIY Chatroom Home Improvement Forum
Old 04-29-2016, 11:34 AM   #1
Rewards Points: 76
Had vents installed in attic due to peeling celing
Hello when would be a good time ti stsrt to scrape celing to get rid of all the peeling paint thats in the room. What could be the cause of this i just installed three vent on attic. Pic posted
Sent from my SM-G900V using Tapatalk
charles3526 is offline   Reply With Quote
Old 04-29-2016, 12:32 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 906
Re: Had vents installed in attic due to peeling celing
Tough to see what the issue is. Have you tried looking from the attic side?
Old 04-29-2016, 12:43 PM   #3
Rewards Points: 166
What type of vents, where and why? Attic vents work from low to high so need some of both.
Any exhaust fans being vented into the attic or at the soffits?
Bud
Bud9051 is offline   Reply With Quote
Old 04-29-2016, 01:14 PM   #4
Rewards Points: 76
Its pelling off the wall its no humid they are exhusted from the attic in the middle of the roof
Old 04-29-2016, 01:23 PM   #5
Rewards Points: 166
Charles, your short posts are not giving us enough information to help you.
1. Are you trying to vent the attic?
2. Why?
3. Is there any other ventilation up there, at the soffits, ridge, or gables?
4. You said ceiling, now you say walls?
Bud
Old 04-29-2016, 01:25 PM   #6
Rewards Points: 76
Hello sorry i have a ridge vent two gables on either side of house i now installed vents. My house which is a ranch i saw bubbleing on the ceiling after guests left the house. The problem is with the celing sorry if i said walls
Old 04-29-2016, 01:43 PM   #7
Rewards Points: 166
Ok, we're struggling but we are getting there.
Attics are often hot and that does not cause paint to peel. Moisture does, but that moisture would be coming from inside the house.
What state are you in so we can judge the climate?
Was the ceiling recently painted?
Can you get into the sttic to inspect the top side of the problem areas?
Bud
Also, is there an air conditioner up there?
The Following User Says Thank You to Bud9051 For This Useful Post:
Windows on Wash (04-30-2016)
Old 04-29-2016, 01:51 PM   #8
Rewards Points: 76
Ok no ac in the attic im in new york. No leaks any where attic is dry
Old 04-29-2016, 03:48 PM   #9
Rewards Points: 166
Have you been up there or can you get up there to see the top side of those bad spots?
Bud
Old 04-29-2016, 05:00 PM   #10
Rewards Points: 11,450
Common cause of peeling paint is that the surface was not clean when it was painted.
SPS-1 is offline   Reply With Quote
Old 04-29-2016, 06:49 PM   #11
Rewards Points: 76
What do u mean clean? We lived here two years and its slowy peeling within the two years when moving in i put celing paint on
Old 04-30-2016, 12:22 PM   #12
Registered User
Rewards Points: 526
Check Bud's post #9, you may find the ceiling insulation lacking in those spots allowing room moisture to condense there due to plaster temps reduced for condensation.
Gary
Attic Modification: Soffit Vents, Whirlybird Roof Vents, Airflow? TheSaint Building & Construction 1 07-08-2014 07:02 AM
How to plan for attic ventilation for central air when modifying gable vents? Ocelaris Roofing/Siding 13 03-21-2013 08:50 AM
Attic Ventillation Problem. Why Now? Hubs Roofing/Siding 2 03-19-2013 10:23 AM
5 year old home - builder never installed attic vents DIYguy2000 Building & Construction 20 09-16-2011 09:04 AM
Attic project - Would like opinions whataboutj Insulation 6 06-29-2011 03:07 PM
