Garage Too Cool - Insulation - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By Bud9051
Old 12-25-2017, 11:14 AM   #1
Rewards Points: 68
Hi everyone. Just a question
The garage in oir house is too cool. Here same pictures.
Should be put insulation bewteen studs? And after drywall.
But when i go to pickup samething in there i felling like i am on the street.
So is a good idea insulate the garage?
What to you thinks guys?
Thanks!
Garage too cool-15142221299381295423079_1514222162273.jpg   Garage too cool-1514222175856542476329_1514222186393.jpg   Garage too cool-20171225_115334_1514222437239.jpg
pavlito24 is offline   Reply With Quote
Old 12-25-2017, 11:26 AM   #2
Rewards Points: 88
Re: Garage too cool
Always ...if affordable to the owner and they like working in them. On attached garages, it saves more heat/cool being pulled from the home.
Gregsoldtruck79 is offline   Reply With Quote
Old 12-25-2017, 11:31 AM   #3
Rewards Points: 312
Re: Garage too cool
The temperature in any building is a balance between the heat leaving through wall, ceiling, and such vs the heat entering. In your garage the only heat entering is what escapes from your house through the connected wall and some solar during the day. Obviously the toughest area is the garage door and there are dew options there. Insulate everything perfectly and the temperature will still be cold as there is so little heat getting in.
However, insulating and air sealing are the first steps needed before adding some heat. The better job you do the better the results of heating. Even if it is just to kick it up a notch.
Bud
Dave Sal likes this.
Bud9051 is offline   Reply With Quote
Old 12-25-2017, 12:42 PM   #4
Rewards Points: 68
So its better insulate than nothing !!!
Which will be the best (R/ price) insulation to use in the garage.
And what is the way to do the job?
Insulation - vapor barrier - and drywall
Old 12-25-2017, 04:16 PM   #5
Usually Confused
lenaitch's Avatar
Rewards Points: 116
Re: Garage too cool
Is the ceiling insulated? Insulating the walls certainly can't hurt. It will help keep it a tad warmer in the summer and cooler in the winter but not a whole lot since there is no heat source, but it is the first step in any temperature management. A big source of heat loss is probably through the garage dooor. Fibreglass batts are likely the cheapest, Roxul is my preferred. I believe vapour barrier is code in Ontario but I'm not certain in unconditioned space. I believe some types in rigid insulation are considered to their own vapour barrier if installed properly.
Thanks!
Sorry, you lost me with that sentence.
_________________________________
Ubique
lenaitch is offline   Reply With Quote
Old 12-25-2017, 06:25 PM   #6
Rewards Points: 68
Re: Garage too cool
Yes ceiling is insulated
But when i go to pickup something in there i felling like i am on the street.
I meaning temperature is like outside (-30) i dont pretend temperature will be the same like inside (20) but at least (-10)
Wiring for new attached garage bakerunc22 Electrical 5 12-27-2016 09:02 PM
What are some ways to cool a garage, it's an oven Alumifab General DIY Discussions 22 07-07-2016 11:40 AM
Garage Roof Support & 2nd Floor Addition Info? olimits7 Building & Construction 3 10-15-2012 06:42 PM
Subfeed to New House from Existing Garage??? scuba.man Electrical 2 06-21-2012 07:54 AM
unconditioned garage reillyoevans HVAC 3 08-20-2011 06:29 PM
