Garage Insulation - Insulation - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-04-2015, 11:44 PM   #16
Rewards Points: 188
Originally Posted by Gary in WA View Post
Because you have a low pitch roof angle, 2" air space under the roof sheathing is better than our code required minimum 1" air space. You can add rigid foam board to the bottom of the horizontal ceiling joists (eliminating thermal bridging of the wood) with cavity fill above that- up to some baffles made of rigid foam board as here- separating the air space from the cavity; http://www.buildingscience.com/docum...n-roof-venting
Never let cavity insulation (other than rigid FB) abut a cold sheathing to transmit warm temps to cold roof- conduction loss of R-value.
Gary
Interesting!
Unfortunately I can't use the rigid FB between the ceiling joists and drywall because I can't afford to lose any head room, as it's a pretty low ceiling.
Here's my next question. Should I leave a 1-2" space between the insulation and roof boards all the way to the roof edge? I was thinking of going right up against the roof boards at the very sides of the roof, but I think I could run into ice damming problems in the future. Better to be slightly less thermal efficient than causing other problems I suppose.
JA Boomer is offline   Reply With Quote
Old 02-05-2015, 05:08 AM   #17
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 942
You have to provide for unobstructed ventilation pathway. If the roof pitch is steep, the smaller gap is less worrisome, however, you really should have about a 2" continuous gap to allow for the space to vent.
Old 02-05-2015, 09:54 AM   #18
Rewards Points: 188
Even if that means the very edges of my garage will have almost no ceiling insulation???
Old 02-05-2015, 10:42 AM   #19
Rewards Points: 942
I think Gary referenced it earlier, when it was mentioned about putting rigid foam over the top of that outer top plate.
Caulk, foam, or otherwise seal that top plate connection against any air leakage. After that is completed put the highest R-value foam, rigid board, that you can in that location.
If you use something like a polyiso bored, you get the maximum R-value you can per inch at that location. Be sure to seal that phone where it connects to the framing into the attic floor as well.
Garage insulation.. sh40674 Insulation 4 01-09-2014 09:38 AM
Insulating your attic Bob Mariani How To Guides 5 07-07-2013 08:49 PM
Finishing the garage with insulation and drywall. Snapper12 Insulation 2 10-24-2012 06:14 AM
Rafter Vents and Insulation nofx1981 Roofing/Siding 15 03-10-2010 08:14 PM
Insulation questions for new detached garage mpt1123 Building & Construction 2 03-01-2009 08:18 AM
