Garage Insulating - Insulation - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 1 Post By Bud9051
  • 1 Post By Bud9051
Old 08-19-2019, 04:08 PM   #1
Rewards Points: 312
Garage insulating
got the walls done, now onto the ceiling. Plan is to shiplap the walls and drywall the ceiling. What is the easiest to install in the ceiling? i used the kraft faced on the walls, but is that easy to work with on the ceiling? between holding it, and stapling the 'tabs' seems like a real pain.... maybe install sheetrock, then blow in?
KPDMinc is offline   Reply With Quote
Old 08-19-2019, 04:52 PM   #2
Rewards Points: 154
Re: Garage insulating
If it is open from the top you can hang the drywall and then lay batts or whatever from above. Be sure to install baffles while you have easy access. I prefer unfaced Roxul an it fits tight and easy to handle.
Being in a cooling climate You need to either avoid using a vapor barrier or install it towards the exterior. But being a garage it depends upon what is going on inside.
Bud
KPDMinc likes this.
I volunteer my help and opinions, but you are responsible for what YOU choose to do with that information.
Bud9051 is offline   Reply With Quote
Old 08-19-2019, 05:11 PM   #3
Rewards Points: 312
Bud
Re-finishing the garage with shiplap walls and VCT tile (black and white race pattern) and want to maintain a little cooler than outside. Play area for grand babies, and an extension of the house for parties, etc....
Old 08-19-2019, 05:21 PM   #4
Rewards Points: 154
Extra space does better when it is either conditioned or totally not. Now, I'm from up north and need to rethink your warm climate as your condensation issues are far less then what we deal with.
In general you will want to keep the warm humid air away from that cool interior surface. That would put your vapor barrier to the outside not the Kraft faced on the inside. But your risk is low so I would not change the walls. But in the ceiling I would use unfaced insulation.
Bud
KPDMinc likes this.
