Garage Header Insulation - Insulation - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By Bones519
Old 02-23-2019, 10:15 PM   #1
Garage header insulation
I was just wondering a couple of things about insulating my garage. I've insulated all the walls. I used rolled insulation with paper facing. Do I need to use any additional vapor barrier, and should I insulate the headers over the doors and windows? These are exterior walls. The ones adjacent to my house were insulated and sheetrocked when the house was built. Any advice or expertise would be welcomed! Thanks!
Bones519 is offline   Reply With Quote
Old 02-23-2019, 10:21 PM   #2
retired framer
Rewards Points: 364
Re: Garage header insulation
The paper is vapour barrier and if the room at the headers you put in what every you can fit, sometimes there is no room for anything.
Do not use flat bottom gables with scissor trusses.
https://www.fema.gov/media-library-d...6/chapter7.pdf
figure 7-14
Nealtw is offline   Reply With Quote
Old 02-23-2019, 10:24 PM   #3
There's a little room. But is it necessary?
Old 02-23-2019, 10:33 PM   #4
retired framer
Rewards Points: 364
I really doesn't help a lot, I have seen layers of foam board used to fill it up but often we fill that space with a full sized beam and there is no room.
figure 7-14
Old 02-23-2019, 10:42 PM   #5
Thanks! I appreciate it.
Nealtw likes this.
Old 02-24-2019, 12:19 AM   #6
Rewards Points: 1,528
I filled mine with foam board as Neal mentions... itís easy enough to do and not expensive..
ryansdiydad is offline   Reply With Quote
Old 02-24-2019, 05:59 AM   #7
Rewards Points: 1,094
Why not insulate ? You insulated the rest of the walls do it now while it is open .
Porsche986S is offline   Reply With Quote
Old 02-24-2019, 11:43 AM   #8
Rewards Points: 1,060
You should absolutely insulate those headers! Use a piece of rigid foam board and not fiberglass batts there. You can also use a little canned spray foam to seal the corners if you want to. If you have the canned foam or are willing to spend the $4 for it, get the low expansion window and door version and fill the little gaps around the window framing.
The reason you want to insulate that gap even though it is small, is because it will otherwise be a thermal bridge from the outside. That little bit of foam breaks the thermal transfer to the outside so it does more than it's low R value would lead you to believe. The window is already a cold spot, so an uninsulated header is going to make it worse, and the void can pull warmer room air in where it will condense on the cold wood giving mold an opportunity to grow. That piece of foam has an R value of maybe 5 which isn't much, but it does make a big difference.
Like Neil pointed out, you don't always get that space, but when you do you should definitely take advantage of it.
NotYerUncleBob2 is offline   Reply With Quote
Closet over garage insulation and air flow problem? Homework to do Insulation 0 02-06-2019 07:56 PM
Insulation in attached garage below a living space Vgizzo Insulation 8 01-18-2019 08:47 AM
insulation for bonus room over garage BrianinNC Insulation 33 06-25-2013 05:10 PM
Thermal and Sound Insulation for Bedrooms over garage sunlight33 Insulation 1 04-14-2013 11:20 PM
Garage insulation - to replace or not, and related questions DaveinGA Remodeling 6 12-20-2009 10:25 AM
