Garage Doors Insulation - Insulation - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-07-2015, 11:52 PM   #16
Registered User
Rewards Points: 526
The door has a frame for drilling, attaching with self-tappers (hex-head screws) actually- remove one of them and look at it. Has a cut across the tapered threads for piercing metal without drilling- I installed them for 3 months before travel time was too excessive. Forget tape. IMO, use some flat washers with st screws in a grid pattern on each panel, if the FG is compressed enough- the skrim coating should hold together, no perimeter support required. Add more field screws, the FG can't be that heavy.
Gary
Old 10-25-2015, 08:25 PM   #17
Rewards Points: 183
Hi all,
Here is I solved it:
Material used to fix the panels:
1) Braid nylon rope: $ 1.49 x 2
2) Gorilla white duct tape (only for aesthetics) $11.00
No drills or extra screws, I used the existing ones to pass the rope and create a perimeter on each panel.
It takes time if you are precise as I tend to be, you have to cut the panels from 22" to 21" inches and customize all the corners, you need somebody to help to keep the panels in place when fixing the retainer clips and tight the rope.
I like the result and I hope this helps other Canadians with doors like mine to find a cheap and 'light' way to fix the panels.
No adjustment to the force of the garage door opener was needed.
Alex
Metallo is offline   Reply With Quote
Do I really need r50 insulation in garage attic? recklessrick Insulation 11 04-27-2014 07:45 PM
Insulating your attic Bob Mariani How To Guides 5 07-07-2013 08:49 PM
Combine 7' garage doors into one 16+ ft door - connect brick lintels Irestone Concrete, Stone & Masonry 12 03-22-2012 03:51 PM
Repair or Replace Garage Doors??? jbird0005 Windows and Doors 2 12-10-2011 06:42 AM
