Former Back Porch Now Current Bathroom - Insulation - DIY Chatroom Home Improvement Forum
Old 10-05-2016, 02:54 PM   #1
Rewards Points: 6
Former back porch now current bathroom
I am remodeling a recently purchased home. The previous owners converted the back porch into a bathroom. (good idea) They fed the plumbing through the floor joists, put some foam insulation below the joists (most of which is falling off) then they added electric baseboard heating, cut some vents in the floor and crossed their fingers that heat would fall instead of rise (bad idea). There were a number of close calls with pipes freezing.
Currently I have the floor, subfloor and all walls removed. What do I do now? I could try more foam boards under the joists, (there is about 3-4 feet of open air before the ground former porch remember), force air in between a joist and vent up through the floor? This would be ok for the water pipes in that joist but what about when they cross over to other joists that don't have air forced through them?
Former back porch now current bathroom-img_4199.jpg   Former back porch now current bathroom-img_4197.jpg   Former back porch now current bathroom-img_4198.jpg
danfman99 is offline   Reply With Quote
Removing concrete block porch - Phase 2 of back yard deck renovation stevergee General DIY Discussions 7 09-19-2016 08:21 PM
Replacing single step out back porch to patio atcstretch Building & Construction 1 04-02-2013 10:24 PM
Rewiring Bathroom & Den heyjoe91 Electrical 4 02-21-2013 04:22 PM
Back porch Remodel-ish :) tripflex Project Showcase 5 04-01-2010 12:26 PM
Slight electrical current in bathroom faucet water + other unusual electrical events story Electrical 9 09-16-2009 10:28 PM
