Foam Calculator - Insulation - Page 2 - DIY Chatroom Home Improvement Forum
Old 05-09-2015, 01:02 AM   #16
Rewards Points: 70
When applying spray foam, specifically closed cell, it is optimal to do it in more thin coats than in one thicker coat do to the way it cures, If you spray some for example and you let it cure, then you slice it open you will notice it appears porous inside and more smooth on the outside. This is key to getting maximum moisture barrier from it. Each layer will give another outter barrier. More layers in the same depth gives more protection then less thicker layers.
jayb614 is offline   Reply With Quote
Insulating an Attic - Spray Foam in the Rafters v. Cellulose on the Floor esteve999 Insulation 5 12-13-2014 10:29 AM
vinyl over aesbestos - how avoid nailing into wires? which foam board is best? gunner666 Roofing/Siding 12 08-07-2014 07:57 PM
B-12 Chemtool versus SeaFoam DrHicks Automotive Repairs 16 10-01-2012 08:57 PM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
Hybrid wall insulation consisting of 2" rigid foam + 2x4 fiberglass batts? TitaniumVT Building & Construction 15 09-14-2010 02:50 AM
