Floor Truss Insulating - Insulation - DIY Chatroom Home Improvement Forum
Old 11-21-2017, 03:28 PM   #1
Floor Truss insulating
I have read many of the threads on insulating a room above a unheated garage and they have been helpful but I have not seen mention of insulating when the ceiling/floor above is 16" 2x4 floor trusses and not joists.
Im considering treating the trusses like wall cavities and cut jigs to use cut the fiberglass insuation in the triangle shapes that match the trusses since they are 3 1/2" wide. that way the truss would be fully insulated from the bottom to the top of the truss and then come back and place batts between the trusses.
Any thoughts?
ME
Mehman is offline   Reply With Quote
Old 11-21-2017, 03:39 PM   #2
retired framer
Rewards Points: 360
Re: Floor Truss insulating
Any thoughts?
ME
I have no info as I have not seen this floor done, but cut shapes to fit in the holes will leave the batts 90* to the heat, I don't think you want to do that.
Old 11-21-2017, 05:02 PM   #3
Rewards Points: 4,864
Not the expert in this area but I think the problem with the trusses is the continuous structure (which would conduct the cold), not the air space in the web.
stick\shift is offline   Reply With Quote
vapor barrier or insulating sheathing in attic FileOpen Insulation 0 05-11-2014 10:30 PM
Insulating furnace/utility area cbrc5eric Building & Construction 3 04-30-2010 12:03 PM
Options for insulating a concrete block house Ptron Building & Construction 7 04-05-2010 03:55 PM
Insulating basement ceiling - your recommendations? jtmann HVAC 8 11-24-2009 04:44 PM
Insulating brick above & close to grade Peter Shepherd Building & Construction 1 09-16-2009 06:41 AM
