Floor Joist Insulation And Lighting - Insulation - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 1 Post By Mystriss
  • 1 Post By Nealtw
Old 01-22-2020, 08:14 PM   #1
Mystriss's Avatar
Rewards Points: 7,354
Floor joist insulation and lighting
I would like to put insulation for sound-proofing and "pop-up"/"between the joists" radiant heat.
I know you're supposed to put special cans on recessed lights when they're going to be near insulation. Is there anything special I need to plan on doing around my ceiling light fixtures that'll be surrounded by insulation?
(I am looking at rockwool/mineral fiber insulation, though I might do open cell spray foam as well/instead if it can go around my radiant floor heating stuff)
(I'm not a professional, just a homeowner who dabbles in a bit of everything DIY)
Mystriss is offline   Reply With Quote
Old 01-22-2020, 08:41 PM   #2
retired framer
Rewards Points: 866
Re: Floor joist insulation and lighting
Insulated rated cans IR. or just use LEDs that look like pots.
Go with resilient channel too for the sound.
Rock wool or fiberglass are both good.
Do not use flat bottom gables with scissor trusses.
https://www.fema.gov/media-library-d...6/chapter7.pdf
figure 7-14
Nealtw is offline   Reply With Quote
Old 01-22-2020, 08:55 PM   #3
Mystriss's Avatar
You don't have to worry about the code around the LED pots? hmmm
I'm kind of thinking to replace almost all the lights in the house with LEDs. I don't mind the idea of buying new fixtures every 5-10 years since it's a good excuse to paint the walls/ceiling :P
Nealtw likes this.
Old 01-22-2020, 09:07 PM   #4
retired framer
Rewards Points: 866
I don't know good or bad brands but watch the video here.
https://www.lotusledlights.com/led-r...w-construction
Mystriss likes this.
figure 7-14
