Flooded Crawl Space After Heavy Rain Insulation Damage? - Insulation - Page 2 - DIY Chatroom Home Improvement Forum
Like Tree16Likes
Old 06-13-2019, 01:50 PM   #16
retired framer
Rewards Points: 886
Re: Flooded crawl space after heavy rain insulation damage?
The major clean up first, you still have wood forms around some concrete, that should not be there and the dirt need so to smoothed out if not levelled before poly is put down and sealed around obstacles and walls.
Kemper100 likes this.
Do not use flat bottom gables with scissor trusses.
https://www.fema.gov/media-library-d...6/chapter7.pdf
figure 7-14
Old 06-13-2019, 08:29 PM   #17
APA
Rewards Points: 384
Get you a box of contractor trash bags and bag up all that junk and ruined insulation.
APA is offline   Reply With Quote
Old 06-13-2019, 08:32 PM   #18
APA
Rewards Points: 384
How old is this house? Looks like rough-cut lumber. Nothing wrong with it. Just interested.
Old 06-15-2019, 01:11 PM   #19
Rewards Points: 304
The property was built: 1920
Kemper100 is offline   Reply With Quote
Old 06-15-2019, 01:17 PM   #20
Rewards Points: 304
Old 06-15-2019, 01:22 PM   #21
retired framer
Rewards Points: 886
Originally Posted by Kemper100 View Post
I bet that was a fun job.
For the water you really need a drain system around the perimeter, some inches lower than the dirt inside.
figure 7-14
Old 06-15-2019, 09:20 PM   #22
Rewards Points: 304
Moar pics from today gravel bonanza...
Nealtw likes this.
Old 06-19-2019, 06:47 PM   #23
Rewards Points: 304
Are there spray foam insulation kits safety concerns
If I wanted to pick up a kit and do it myself...I found this off the interwebs.
"homeowners who are exposed to isocyanates and other spray foam chemicals in vapors, aerosols, and dust during or after the installation process "run the risk of developing asthma, sensitization, lung damage, other respiratory and breathing problems, and skin and eye irritation."
Old 06-19-2019, 07:39 PM   #24
Rewards Points: 4
Originally Posted by jmon View Post
First, get a respirator, then remove all that wet and molded insulation, bag it up and throw it away. Before you install the new insulation may I suggest a couple of tips; make sure you get some fans and dehumidifier down there and dry it all up really good. Treat any mold that may have grown on any wooded area with a solution of water and bleach.
This is all good information. Except for the water and bleach. Bleach doesn't do much against mold on porous materials. It works great in the kitchen and bathrooms where hard surfaces are abundant.
Get a product designed for Mold Removal on all surfaces. There are several out there. Concrobium is one of the major names in mold remediation.
As others have said, first correct where the water is coming from. Otherwise anything else you do is moot. (You can take all of the insulation out, not just what looks wet. Get it ALL out as mold has probably already taken root) This goes for any standing water and the dirt that came with it. Who knows what is in the dirt.
Once the source of the water intrusion has been taken care of, dry it out. Use fans, dehumidifiers, etc.. You can get a dehumidifier with a pump so that it can pump the water it collects to a sump or outside the house.
As it is drying, you can spray all the areas to kill the mold and prevent it from coming back. This means the concrete, wood, metal, everything. Mold can grow on most anything as long as it has moisture and food. Even on metal if it has something on it that the mold likes.
Once the mold killer has been applied according to directions, then you can put in new insulation. Consider using Mold and mildew proof insulation like rock wool (mineral wool) insulation. It is also fire proof.
The only stupid question is the one you DON'T ask!
ktownskier is offline   Reply With Quote
Old 07-04-2019, 06:35 AM   #25
Rewards Points: 304
Answer please!!!!!!!!!!!!!!!!!!!!!!!
Old 07-04-2019, 06:38 AM   #26
Rewards Points: 304
Originally Posted by 3onthetree View Post
3rd times the charm on those photos. Once it gets overly dirty, mold can take to whatever grime is on it, especially ones touching the dirt and acting like sponges. Luckily batt insulation is pretty cheap. Start with getting the water problem solved outside and putting a vapor barrier over that dirt. Make sure you have proper ventilation. Tuck those flex ducts (don't know if sag or clearance routed) and wires tight to the joists then you can deal with the insulation.
Surprisingly I don't see any evidence of mold...
Crawl space insulation badger73 Insulation 10 07-11-2018 09:10 PM
Crawl Space insulation, encapsulation Boneill230 Insulation 6 02-17-2015 09:12 PM
Impact of waiting on rim joist and stem wall insulation of crawl space this winter ProGreen Insulation 0 11-21-2014 10:06 AM
Flooring cold over crawl space cere19 Insulation 2 11-14-2013 11:38 PM
Unvented crawl space insulation ehardman Building & Construction 3 01-13-2009 12:44 PM
