Flooded Crawl Space After Heavy Rain Insulation Damage? - Insulation - DIY Chatroom Home Improvement Forum
Like Tree16Likes
Old 05-12-2019, 11:55 AM   #1
Rewards Points: 190
Flooded crawl space after heavy rain insulation damage?
So yea when it rains really heavy my crawl space can flood. The batt insulation in some areas is loose and hanging and it's not faced so I guess it got wet from condensation.
Question: Is the insulation trashed from the dampness in the crawl and needs to be replace or do I just fasten in back in place?
It kinda looks like this picture of the net.
Kemper100 is offline   Reply With Quote
Old 05-12-2019, 12:40 PM   #2
Rewards Points: 2,584
Re: Flooded crawl space after heavy rain insulation damage?
First, get a respirator, then remove all that wet and molded insulation, bag it up and throw it away. Before you install the new insulation may I suggest a couple of tips; make sure you get some fans and dehumidifier down there and dry it all up really good. Treat any mold that may have grown on any wooded area with a solution of water and bleach.
Second, check around the outside of the foundation to see if anything can be corrected like any loose or missing drain pipes/gutters. Try to have the water flow away from foundation, etc.
Finally, I would install a sump pump in the lowest part of that crawl space so the water has a place to go when it does rain heavy like that to prevent a situation like this from happening again. After everything is dried out really good and the water infiltration is corrected, then put the new insulation in. Just a suggestion.
Hope you get dried out soon and it stops raining kemper.
jmon is online now   Reply With Quote
The Following User Says Thank You to jmon For This Useful Post:
Kemper100 (05-12-2019)
Old 05-12-2019, 03:41 PM   #3
Retired Handyman/Painter
Johnny_inFL's Avatar
Rewards Points: 1,268
that, to me, is a "Mold Incubator".
when it warms up with no ventilation, anyone that enters
that space is putting their health at serious risk.
your priority should be:
#1 ~ get ahold of the flood water situation and fix it - pronto.
#2 ~ establish some kind of continuous fresh air flow - pronto.
and yes, in my very personal opinion, if your situation even slightly
resembles that one photo, ALL of the insulation is toast and should
be removed A.S.A.P.
these are only our opinions and suggestions.
your house = your call.
Kemper100 and ktownskier like this.
-- Failure is proof that you at least tried ~ now, go do it again, and again, until you get it right --
Johnny_inFL is offline   Reply With Quote
The Following User Says Thank You to Johnny_inFL For This Useful Post:
Old 05-12-2019, 06:09 PM   #4
APA
Rewards Points: 248
You are going to find very few crawlspaces without mold. Wear a mask if it makes you feel better. Just remember that the advice on here is from guys who are not spending their own money. Get rid of the standing water, close the foundation vents except for one on each end. Put a 70-pint dehumidifier in the center of the space and two box fans in the far corners facing opposite directions to circulate the air in a circle. If you do not have a 6mil vapor barrier over the dirt, do this first as soon as the water soaks into the ground. Run the de-humidifier in continuous for 2 days. Re-assess after that. You will probably be surprised. Get rid of any insulation that has fallen. If it is sagging, you can get it back into place with insulation supports you can buy by the 100 at lowes for $15. However, you will need to figure out why the crawl is flooding and get that fixed. If you have mold or mildew on joists, just get under there an clean them wit mild bleach solution. Jus go a little at a time over the course of a few weeks as not to get frustrated.
Source: Been there. I live in a humid area.
Kemper100 likes this.
APA is offline   Reply With Quote
The Following User Says Thank You to APA For This Useful Post:
Old 05-12-2019, 09:53 PM   #5
retired framer
Rewards Points: 4,510
Fix the drainage problem first.
Kemper100 and Mystriss like this.
Do not use flat bottom gables with scissor trusses.
Old 05-15-2019, 08:24 AM   #6
Rewards Points: 603
Take a close look at the perimeter walls in the crawl space and look for mineral deposits. If you see deposits, then part of the problem is water coming through the walls. This was pointed out to me by a home inspector while house hunting.
rjordan393 is online now   Reply With Quote
Old 05-15-2019, 08:46 AM   #7
retired framer
A kinda looks like picture just will not do, as you don't know what the problem is, you don't know what picture to compare too.
Old 05-27-2019, 10:01 AM   #8
Rewards Points: 190
Not really following you. The picture is a representation of similar conditions of my crawl space.
The issue is many but mainly the water infiltration causing damage and undesirable conditions under the house.
That said I'll post actual picture of the space.
Nealtw likes this.
Old 06-05-2019, 12:48 PM   #9
Rewards Points: 190
Old 06-05-2019, 03:24 PM   #10
retired framer
Originally Posted by Kemper100 View Post
The photos are not opening for me
Old 06-05-2019, 04:09 PM   #11
Mystriss's Avatar
Rewards Points: 4,438
I'd say the insulation is dead, I don't think it's worth keeping moldy insulation in like any case.
When you put new insulation in the floor joists, put on a vapor barrier to keep it out of the water in the future.
A sump pump would be a good idea, if you've a cement floor that makes it more difficult unfortunately.
Our basement is actually just a hair above the water table so it has constant water coming up through the dirt floor. Our floor has a huge continuous sheet of plastic and trenches that go into the sump pump that runs year round (even when it's 40*F below outside.) We put all of our stuff on pallets in case the sump pump goes out again - the first time it happened my husband lost his military keepsakes chest so we do the pallets now
(I'm not a professional, just a homeowner who dabbles in a bit of everything DIY)
Mystriss is online now   Reply With Quote
Old 06-13-2019, 12:05 PM   #12
Rewards Points: 190
I'm not too sure what happened...
Old 06-13-2019, 12:26 PM   #13
Rewards Points: 190
Old 06-13-2019, 12:28 PM   #14
Rewards Points: 190
Old 06-13-2019, 12:51 PM   #15
Hammered Thumb
Rewards Points: 730
3rd times the charm on those photos. Once it gets overly dirty, mold can take to whatever grime is on it, especially ones touching the dirt and acting like sponges. Luckily batt insulation is pretty cheap. Start with getting the water problem solved outside and putting a vapor barrier over that dirt. Make sure you have proper ventilation. Tuck those flex ducts (don't know if sag or clearance routed) and wires tight to the joists then you can deal with the insulation.
3onthetree is offline   Reply With Quote
Crawl space insulation badger73 Insulation 10 07-11-2018 10:10 PM
Crawl Space insulation, encapsulation Boneill230 Insulation 6 02-17-2015 10:12 PM
Impact of waiting on rim joist and stem wall insulation of crawl space this winter ProGreen Insulation 0 11-21-2014 11:06 AM
Flooring cold over crawl space cere19 Insulation 2 11-15-2013 12:38 AM
Unvented crawl space insulation ehardman Building & Construction 3 01-13-2009 01:44 PM
