Flash And Batt In 2x4 Wall System Zone 5 - Insulation - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 2 Post By Nealtw
Old 02-16-2020, 09:39 AM   #1
Rewards Points: 159
Flash and Batt in 2x4 wall system zone 5
Hey all,
Looking to get a home built in climate zone 5. The builder we like has been building his homes for the last 12 years using the flash and batt system. Builder sprays 1/2" closed cell spray foam inside wall cavity with an R13 batt. Typical 2x4 wall with osb sheating and Tyvek on exterior.
I've researched this to no end and it just does not seem like a good idea in our climate zone. Someone tell me I don't need to worry! We really like the homes.
Opinions?
Thanks,
Ron
rferoni is offline   Reply With Quote
Old 02-16-2020, 09:53 AM   #2
retired framer
Rewards Points: 282
Re: Flash and Batt in 2x4 wall system zone 5
Originally Posted by rferoni View Post
Hey all,
Opinions?
Thanks,
Ron
I have not seen a house built with 2x4 outside walls for 30 years.
And we are a little warmer out here.
Yodaman and Chris616 like this.
Do not use flat bottom gables with scissor trusses.
https://www.fema.gov/media-library-d...6/chapter7.pdf
figure 7-14
Old 02-16-2020, 10:22 AM   #3
APA
Rewards Points: 382
A lot of guys are doing 15+5 where they put an inch of R5 foamboard on the outside and r-15 batt on the inside. That is the only way I would do a 2X4 wall now. Most are and have been using 2X6 walls here.
APA is offline   Reply With Quote
Old 02-16-2020, 10:55 AM   #4
Rewards Points: 11,386
Does he put a vapor barrier in that assembly ? Where ?
Seems that the system as mentioned by APA is becoming popular. The exterior foam board is taped air tight and it becomes the vapor barrier. But for this to work, the exterior foam has to be thick enough that you don't get any condensation on the interior face of the foamboard. In Michigan, I don't think R5 (mentioned by APA) is quite sufficient to ensure no condensation on the inside face. I certainly don't see how R3 (half an inch of PU sprayfoam) will avoid condensation on the inside face.
But not sure if half an inch of closed cell sprayfoam is going to be a vapor barrier. But if he puts a conventional poly vapor barrier on the warm-in-winter side, what would be the point of the sprayfoam?
I am no expert, but I don't like it either.
SPS-1 is offline   Reply With Quote
Old 02-16-2020, 02:36 PM   #5
Rewards Points: 159
Is Tyvek considered a vapor barrier? From exterior to interior the wall system is cladding(mostly vinyl siding)-Tyvek-OSB-sprayfoam-R13 batt-drywall.
Ron
Old 02-16-2020, 04:57 PM   #6
I will stick to my previous opinion.
