Finishing Ceiling Insulation W/ Paneling - Insulation - DIY Chatroom Home Improvement Forum
Like Tree4Likes
  • 2 Post By chandler48
  • 1 Post By joecaption
  • 1 Post By chandler48
Old 11-29-2019, 07:03 PM   #1
Rewards Points: 140
Finishing ceiling insulation w/ paneling
In Los Angeles, by code you have to finish ceiling insulation with drywall or paneling. Can you just use any paneling, even if it's labelled as "wall" paneling? If so can anyone recommend a LIGHT paneling? I would like to find some thin paneling that is much lighter than drywall.
I would build some 1 X 2 framing to hold up the paneling. Looking to insulate an open beam ceiling.
CutinCorners is online now   Reply With Quote
Old 11-29-2019, 07:48 PM   #2
Naildriver
chandler48's Avatar
Rewards Points: 908
Re: Finishing ceiling insulation w/ paneling
IF it says "covered", then unless they stipulate the covering, it can be paneling. However, be aware of sag with thinner paneling. You may have to put your strapping closer together than normal to keep it straight.
Dave Sal and CutinCorners like this.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
The Following User Says Thank You to chandler48 For This Useful Post:
CutinCorners (Yesterday)
Old Yesterday, 05:50 AM   #3
Rewards Points: 666
Any concerns about fire rating ?
Porsche986S is offline   Reply With Quote
Old Yesterday, 09:46 AM   #4
Rewards Points: 18,102
And what's the plan for covering up all the seams?
I've seen paneling used a few times by DIYS and to me it always looked like poop.
Far better to use drywall or T & G 1 X 6's.
Dave Sal likes this.
Old Yesterday, 11:44 AM   #5
Naildriver
chandler48's Avatar
Rewards Points: 908
++ on the T&G. Yeah, more expensive, but so much more of a solid ceiling and the looks will POP.
Larry......
Old Yesterday, 09:55 PM   #6
Rewards Points: 140
All I care about is being up to code.
I don't want all that weight up there.
Old Yesterday, 10:46 PM   #7
retired framer
Rewards Points: 1,066
What is the concern with the weight, putting up or keeping it up?
Do not use flat bottom gables with scissor trusses.
Old Yesterday, 11:20 PM   #8
Rewards Points: 140
I just think it might be too much weight for this open beam ceiling roof. Beams (3 1/2' X 5 1/4") are 32" (on center) apart. Was discussed a bit in this thread... https://www.diychatroom.com/f9/extra...t-roof-671951/
Drywall would be like 51 pounds per 4X8 sheet. I'm not sure T&G wood would be much lighter.
Old Yesterday, 11:27 PM   #9
retired framer
Now I remember you already have fire rating for the roof, but you will still want 2x4 strapping at least 16" on center. You could look at dropped ceiling
Old Today, 06:26 AM   #10
Naildriver
chandler48's Avatar
Rewards Points: 908
Agreed. With 32" oc, you will need to add strapping, so logic about the sheetrock versus the T&G isn't there. You wouldn't necessarily need the strapping with the T&G. Sheetrock plus strapping would be much more weight than T&G. As far as paneling goes, I would not do it with less than 3/8", but you still would need the strapping.
Larry......
Old Today, 06:55 PM   #11
Rewards Points: 140
Are those sheets of paneling or insulation?
I was thinking of building my own "strapping" between the beams using 1 X 2's, leaving the beams exposed.
Old Today, 07:20 PM   #12
retired framer
With the beams exposed you don't get much insulation.
There are lots of panels that would work with them but i have only insulated the 1/2" sound board type that are painted white on one side.
https://www.google.ca/search?q=drop+...&sa=X&ved=2ahU
