Finishing Basement - Flip Existing R-30 Batts In Ceiling? - Insulation - DIY Chatroom Home Improvement Forum
Old 12-16-2015, 11:07 AM   #1
Rewards Points: 152
Finishing Basement - flip existing R-30 batts in ceiling?
I'm finishing my basement and have a question about the existing R-30 fiberglass batt insulation between the floor joists over head. Currently, it's paper side up (facing our finished upstairs). If I'm finishing the basement space, should I flip the batts around so the paper faces the basement living spaces?
I know it's always paper facing the warm area... but in this case... there are two warm areas. The basement needs the insulation more, I assume?
Thanks!
pburgh19 is offline   Reply With Quote
Old 12-16-2015, 09:03 PM   #2
Registered User
Rewards Points: 526
If between two warmed areas, insulation only serves against sound transmission... leave it be or pull the facing and spread the batts in attic. The facing is to stop moisture migration, none in your case; no great temperature differences/pressure differences.
Gary
PS; you do, however, require some rim wood joist insulation, if none on exterior. Use foil-faced foamboard to stop any moisture from interior/exterior per Energy requirements; http://energycode.pnl.gov/EnergyCode...e=Pennsylvania
The Following 2 Users Say Thank You to Gary in WA For This Useful Post:
pburgh19 (12-16-2015), Windows on Wash (12-17-2015)
Old 12-16-2015, 09:12 PM   #3
Rewards Points: 152
Thank you!
Old 12-17-2015, 12:06 AM   #4
Registered User
Rewards Points: 526
You're welcome, that's why we are here. Wear protective gear if moving it...
Gary
Tags
basement , insulation , r-30
Basement Finishing Plan phoray Remodeling 3 12-20-2013 01:14 PM
How to sound insulate an existing basement suspended ceiling LRosen Insulation 8 03-27-2012 09:04 AM
More Basement Dropped Ceiling Installation Questions markronz Remodeling 7 02-28-2010 03:47 PM
Finishing Basement..ceiling problem cornick Remodeling 12 12-08-2009 10:36 AM
