Fiberglass Vs Rock - Insulation - DIY Chatroom Home Improvement Forum
Like Tree4Likes
  • 1 Post By Nealtw
  • 1 Post By Bud9051
  • 1 Post By FM3
  • 1 Post By Mystriss
Old 04-16-2020, 06:46 PM   #1
Rewards Points: 810
Fiberglass vs Rock
I much prefer to use rock wool rather than fiberglass. It's easier to cut and seems to be safer as the fibers are going throughout the room. I cough when using fiberglass so I wear a mask, I don't seem to need one when using rock wool.
On the internet, says, fiberglass is the #1 in the U.S. while rock wool is the go to insulation in Europe, why is that?
JLawrence08648 is offline   Reply With Quote
Old 04-16-2020, 06:51 PM   #2
retired framer
Rewards Points: 430
Re: Fiberglass vs Rock
advertising.
Windows on Wash likes this.
Do not use flat bottom gables with scissor trusses.
https://www.fema.gov/media-library-d...6/chapter7.pdf
figure 7-14
Old 04-16-2020, 08:05 PM   #3
Rewards Points: 11,420
I prefer Rockwool too.
I thought the Rockwool was more expensive. It seemed to be when I did my attic. But I just checked, and rockwool vs fiberglass are pretty much the same.
SPS-1 is offline   Reply With Quote
Old 04-16-2020, 09:24 PM   #4
Rewards Points: 136
With insulation neatness counts. Rock wool is easier to install neatly, tighter fit and ultimately better insulation.
The reason fiberglass is/was used more often was price.
It also reduces air flow through it.
Bud
I volunteer my help and opinions, but you are responsible for what YOU choose to do with that information.
Bud9051 is offline   Reply With Quote
Old 04-18-2020, 06:54 AM   #5
FM3
Rewards Points: 118
Newer fiberglass insulation is nicer to use than the old kind. Still should wear a mask with it, but I don't consider it all that different from mineral wool.
I think mineral wool is more annoying to install. Newer fb holds its shape well enough yet is more flexible than mineral wool, is lighter than mineral wool, and gives more margin of error in tricky areas.
Even cutting them... "MW is like cutting a loaf of bread." True. But FB only takes one quick slice to cut.
I consider MW a better product overall, mainly due to its better rodent and moisture resistance, but MW isn't that much better, and both are great at being fire-resistant.
MW is usually around twice the price of FB here, which isn't terrible, but FB can get much cheaper during special sales. Maybe it's the catch-22 of if MW was more popular there would be more quantities of it and they would go on sale more.
FM3 is offline   Reply With Quote
Old 04-18-2020, 07:06 AM   #6
Rewards Points: 136
FM3, have you ever tested a wall assembly with mineral wool vs one with FBs with an infrared camera. Energy auditing has ratings for the quality of performance for insulation and the MW walls I have inspected looked great. FB can look good so the difference may come down to how careful the installers are.
Frankly, some installation crews I have seen, speed is the only guideline and they know the drywall will be up immediately behind them and they don't like infrared inspections because their sloppy work can't hide.
Added note, boy have I seen some sloppy fiberglass work.
Bud
Nealtw likes this.
Old 04-18-2020, 08:16 AM   #7
FM3
Rewards Points: 118
Not lately.
Based on the OP's post and this being a DIY site, I did write my post assuming the installer actually cares about the finished result.
Bud9051 likes this.
Old 04-18-2020, 06:37 PM   #8
Mystriss's Avatar
Rewards Points: 7,354
I think what the internet means is "fiberglass is the /cheapest/ in the U.S." [and thus #1 with developers]
Bud9051 likes this.
(I'm not a professional, just a homeowner who dabbles in a bit of everything DIY)
Mystriss is offline   Reply With Quote
Old 04-23-2020, 08:00 PM   #9
I have used Roxul brand “safe N sound” before and really liked it. It is around $48-$50 per bag at Orange store which was around 35-40% more than FG rolls. It recently went under the Buy in Bulk category when buying 16 or more rolls you saved 25% so at that point it was a no brainer. Roxul makes a quality product that I feel has several advantages over FG especially when installed in a damp environment.
Greenlight1 is offline   Reply With Quote
