Fiberglass Insulation Around Wood Burning Fireplace - Insulation - DIY Chatroom Home Improvement Forum
Old 01-10-2016, 11:46 PM   #1
Rewards Points: 188
Fiberglass insulation around wood burning fireplace
Hello,
I have a wood burning fireplace with a gate with glass doors in front of it. If you don't know what I mean by a gate, it's a vertical screen with glass doors placed in front of the firebox. When we moved in there was some old fiberglass insulation placed in between the gate and the fireplace rock work. I replaced this insulation when we were having smoke issues. Had a funny smell coming from the fireplace tonight after I closed the glass doors and I assume the firebox got hotter. I'm wondering if I'm causing the binders in the pink fiberglass insulation to off-gas and potentially release toxins.
Is new, pink fiberglass insulation okay in this situation. Since I've clear up my fresh air intake problem, I probably don't even need the insulation in place anymore, because the smoke problem has been solved.
Thanks, Boomer.
JA Boomer is offline   Reply With Quote
Old 01-11-2016, 06:51 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 766
Air it out. Likely that what is happening is what you said. Just cooking off a bit.
Some wood burning stove questions. Tailor General DIY Discussions 21 10-23-2015 05:13 PM
Convert wood burning fireplace to double sided vestaviascott Concrete, Stone & Masonry 6 10-06-2014 02:28 PM
what wood burning inserts can fit into a Heatilator EC36 prefab fireplace shela Building & Construction 1 03-15-2013 04:17 PM
Fireplace reno help, wood to gas fireplace jsunsun Building & Construction 4 01-15-2013 08:09 PM
Where to go for the best price for fiberglass batting insulation? diy'er on LI Building & Construction 7 08-24-2009 04:01 PM
