Faced Or Unfaced For This Wall And Ceiling - Insulation - Page 2 - DIY Chatroom Home Improvement Forum
Like Tree3Likes
Old 10-02-2017, 10:40 AM   #16
Rewards Points: 118
Re: faced or unfaced for this wall and ceiling
All this being said, it sounds like paper faced is the right solution for the attic floor insulation, correct?
Re-reading your post, i'm wondering if you were referring to insulating the roof rafters, vs insulating the attic floor/breezeway ceiling(I'm doing the latter)
DarrenLevine is offline   Reply With Quote
Old 10-02-2017, 11:11 AM   #17
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 856
If the attic floor is properly air sealed, the vapor retarder level on the insulation is far less important.
Old 10-24-2017, 05:03 PM   #18
Rewards Points: 118
Seems a reply of mine may have gotten lost in the mix:
in the kitchen attic, it's a mess of old faced rock wool, should i take the time to clean it all out, or just lay unfaced r30 over it?
Similar situation in the main attic, old rock wool but newer comfort therm encapsulated r13 on top of it, just filling the 2x6 (maybe 2x8) cavities. Could r30 over all of it, but was concerned about those various vapor retarders currently in place. I understand that the old paper facing probably has degraded, but still, always looking for the experienced opinion on the matter.
cheers
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 6 05-19-2017 04:53 PM
Adding wall with door opening - sloped ceiling and no joist for top plate Jebross Remodeling 11 01-11-2012 09:34 AM
Partition wall supporiting ceiling joists (recommendations for removal) afly007 Building & Construction 3 09-29-2011 10:57 AM
Removing a wall with no ceiling joist above it i77ac_10 Building & Construction 2 01-05-2011 12:30 PM
Wall to ceiling fw2007 Electrical 4 03-31-2008 06:18 PM
