Faced Or Unfaced Pink For Basement Ceiling - Insulation - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 2 Post By Bud9051
Old 11-22-2016, 01:22 PM   #1
Rewards Points: 234
faced or unfaced pink for basement ceiling
Hey guys, so my basement ceiling (old school actual 2x8 wood joists) is unfinished and opened. With the winter coming around I need to get the ceiling insulated as the draft is coming into my living room, dining room and kitchen, but I am nowhere near ready to close the ceiling as of yet, so I am wondering if I should go with faced or unfaced bats or rolls. I have heard that faced is a fire hazard if it is not covered with drywall.
Thoughts?
DeeEyeWhy is offline   Reply With Quote
Old 11-22-2016, 01:46 PM   #2
Rewards Points: 4,864
Re: faced or unfaced pink for basement ceiling
Is the basement not heated? If it is, I would not be insulating the ceiling but your description of a (cold) draft makes me think not.
Personally, Roxul or other brand of mineral wool would be my first thought.
stick\shift is offline   Reply With Quote
Old 11-22-2016, 02:07 PM   #3
Rewards Points: 234
I have a steam boiler system, but I do not have any heating source in the basement, only in the upstairs floors.
Old 11-22-2016, 02:37 PM   #4
Rewards Points: 248
If that boiler is in the basement it is providing a lot of heat. Now, where do those cold drafts originate?? The answer is from the many air leaks into your basement. A typical home, which yours doesn't sound as good, will allow all of the air inside the home to be replaced every 2 to 3 hours. Yours is probably in the 1 to 2 hour range and when the wind is blowing, more frequently than that, burrr. I do energy audits and have helped many home owners locate and seal the source of those cold drafts.
One of the more frequent troubled areas is where the house rests on the foundation and you have a very sensitive test instrument on the end of each arm, your hands. A smoke pencil can also work, but if it is cold you will feel it.
As for fiberglass insulation, it doesn't do much to slow air. The mineral wool is much denser but before you install it, continue your search for air leaks up through the floor.
Air sealing is considered the least expensive and most productive energy improvement you can undertake and it should help with those drafts.
Bud
Dave Sal and Crazyjake8493 like this.
Bud9051 is online now   Reply With Quote
Old 11-22-2016, 02:53 PM   #5
Rewards Points: 234
Hi Bud,
Thanks, I agree wholeheartedly. I have 5 really old slider windows in my basement that need to be replaced, not sure when that is going to happen.
I also have a Bilco door that goes out to my backyard and that not only lets in the cold air but rain as well, but I am unsure if I should get it replaced or simply shure it up with some spray in foam insulation.
Old 11-22-2016, 05:34 PM   #6
Rewards Points: 248
There are many old school tricks to keeping the heat in.
Banking the house is one. In old days they would actually shovel the snow up against the foundation to provide some insulation and block the wind. A modern version of that would be the plastic up against the foundation.
That same plastic could also cover those windows. A little fancier would be the transparent shrink wrap. Either will make a big difference.
I'm up in Maine and I can remember as a kid, putting up and taking down the old wooden shutters. Some old homes had wooden sections that leaned up against the house to protect that foundation.
Today a roll of plastic and a few cans of spray foam or caulking can make a difference.
Best,
Bud
3 way switch with z wave micro switch help emax08 Electrical 3 11-01-2016 05:51 PM
Faced or unfaced? msaeger Insulation 20 09-09-2011 10:04 AM
Insulation - Faced vs. Unfaced + Plastic Sheet WaldenL Building & Construction 4 07-06-2011 11:41 AM
Ceiling condensation icemand Building & Construction 1 12-15-2009 05:16 AM
faced or unfaced insulation wiggs Building & Construction 5 04-19-2006 05:50 AM
