Faced Batts Or Unfaced With Plastic Sheeting - Insulation - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By Bud9051
Old 02-28-2017, 12:22 PM   #1
Rewards Points: 63
Faced batts or unfaced with plastic sheeting
Probably a simple question...maybe a dumb one.
I'm looking to insulate/drywall my garage and from what I'm thinking I have two choices. Wasn't sure if code allows for it though. I can do the standard faced batts and drywall over that, or I could go with unfaced (which is much cheaper), but a huge roll of thick plastic sheeting and put that up then drywall. Any suggestions? If I go the plastic route, is there a specific thickness I need to get?
syogod is offline   Reply With Quote
Old 02-28-2017, 12:38 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 906
Re: Faced batts or unfaced with plastic sheeting
Do you even even require a vapor barrier in this case for an unconditioned space?
What does the exterior wall consist of?
https://energycode.pnl.gov/EnergyCod...?state=Indiana
Old 02-28-2017, 12:42 PM   #3
Rewards Points: 63
In this case, I do as I have a lot of cast iron tools (that are having rust issues right now), and I plan on storing/drying hardwood lumber for woodworking so I need to keep humidity pretty even. May even put a dehumidifier in.
Exterior is wood siding panels similar to this: http://www.homedepot.com/p/Plytanium...3699/100000016
Old 02-28-2017, 01:46 PM   #4
Rewards Points: 906
If the drywall is installed properly and air tight (see Gary's ADA link: https://buildingscience.com/documents/information-sheets/air-barriers-airtight-drywall-approach)
Air movement carries the vast majority of moisture removal from the space and if the drywall is tight, you can maintain humitidy in the garage with no issue assuming the doors are tight.
How much are you going to be pumping in there? Depending on what the what the exterior cladding consists of, you may want to consider the plastic.
The reason I ask about the wall construction is if the exterior wall has a class I vapor retarder in its construction, we worry about putting plastic on the interior and creating a vapor trap.
The Following User Says Thank You to Windows on Wash For This Useful Post:
syogod (02-28-2017)
Old 02-28-2017, 02:02 PM   #5
Rewards Points: 63
Lot of good information, thanks!
Not sure what you mean by 'pumping' exactly...are you talking about how much moisture will I be generating?
As far as I can tell, the exterior wall is just simple wood construction without any sort of vapor retarder. I've cut a hole in it in the past and the cross section simply looks like plywood.
Old 02-28-2017, 02:11 PM   #6
Rewards Points: 906
Whats the cladding...i.e. siding, brick, stucco, etc.?
Pumping was referencing your heating the space and keep in mind, if you store a car in there, they let off quite a bit if they are wet or have snow/ice on them.
Old 02-28-2017, 02:22 PM   #7
Rewards Points: 63
Cladding is pretty much just this stuff screwed (nailed?) directly to the studs, nothing on the inside, so I can see the backside of the wood siding from within the garage.
http://redirect.viglink.com/?format=...99%2F100000016
Probably won't do much heating, maybe an electic space heater if I need to get in there during the winter, but it'll be only while I'm working. Cars are only stored there during storms to protect from hail, otherwise they're outside.
Old 02-28-2017, 03:10 PM   #8
Rewards Points: 166
An unconditioned garage will be a difficult place to keep metal (high mass) items from rusting. Normal air exchange through a building is much higher than expected and overnight it will cool the contents. Then in the morning the air infiltration switches to warmer air with more moisture and those cool contents start to sweat. Even a concrete floor can become wet when there is no leak in the roof.
If the wood you will be storing starts out dry then it will contribute little. But here in the cold north many people learn the hard way about storing green firewood in their garage. All of that moisture goes right to any cold surface, walls and windows.
As for your vapor barrier question, as Windows said not required, but not bad as long as the outside isn't covered with one already.
Bud
Windows on Wash likes this.
Bud9051 is offline   Reply With Quote
Old 03-01-2017, 07:45 PM   #9
Registered User
Rewards Points: 526
Your T1-11 structural siding is rated "Exterior" or Exposure 1" both have multiple layers of waterproof glue and act as a vapor barrier. Do not add plastic (Type 1) vapor barrier to the inside or you will have a double vapor barrier with insulation in the middle. IF ever a moisture/water problem, the wood would mold/rot for you. A paper-faced FG insulation is fine, with perms similar to latex paint. BTW, never use an oil based paint on T1-11, only an acrylic latex primer and finish coat, as per manufacturer.
Gary
Old 03-02-2017, 07:37 AM   #10
Rewards Points: 63
Good to know, thanks everyone!
Faced or unfaced NickyB Insulation 3 04-06-2016 04:22 PM
Insulation - Faced vs. Unfaced + Plastic Sheet WaldenL Building & Construction 4 07-06-2011 11:41 AM
Plastic plywood, Plastic sheets, Plastic decking Spud Building & Construction 1 10-16-2009 04:43 AM
Where can I find 20 MIL Polypropylene (plastic sheeting)? missin44 Building & Construction 10 09-21-2009 06:22 PM
Where can I find 20 MIL Polypropylene (plastic sheeting)? missin44 Landscaping & Lawn Care 1 08-31-2008 10:36 PM
