Existing Basement Insulation? - Insulation - DIY Chatroom Home Improvement Forum
Old 01-23-2020, 08:08 PM   #1
Rewards Points: 4
Hey Fellas,
I'm in the process of remodeling the finished basement of a late 80's home that I recently purchased. Finishing the partial space not currently done correctly with XPS against the foundation wall and floor, and tearing out old drop ceiling and carpet in the space already completed previously.
A bit stuck on what to do with the finished exterior walls in that area (~60 ft total). They used poly against the foundation with a stud wall 1" away insulated with unfaced fiberglass. Not the worst way to do it, especially since most modern building science says to keep the moisture towards the foundation, but not how I would have done it either. Do I rip this down also and start over, or let it be?
Thanks!
jmon22 is offline   Reply With Quote
Old 01-23-2020, 08:31 PM   #2
retired framer
Rewards Points: 600
Re: Existing Basement Insulation?
Originally Posted by jmon22 View Post
Hey Fellas,
Thanks!
We don't know the quality of the work done but as described, it sounds very good. Unless there are problems that need to be addressed I would leave it be. I would pay attention to how they dealt with the rim joist if that is available to you.
Do not use flat bottom gables with scissor trusses.
https://www.fema.gov/media-library-d...6/chapter7.pdf
figure 7-14
Old 01-23-2020, 08:33 PM   #3
Rewards Points: 4
Thanks man. I'm taking care of that when I remove the drop ceiling with XPS and spray foam (properly fire blocked). Sensible answer and probably what I need to hear. I'm just extremely particular about doing things the correct way.
Old 01-23-2020, 08:39 PM   #4
retired framer
Rewards Points: 600
We build the same wall with out the foam and add a vapour barrier behind the drywall with success. Your foam board is or should be a VB so your only worry might be outlet boxes and caulking the bottom of the wall to the concrete floor. You can put gaskets behind outlet covers.
figure 7-14
