Electrical Outlet Sealers Versus Draft Sealing - Insulation - DIY Chatroom Home Improvement Forum
Old 12-30-2013, 08:08 PM   #1
Rewards Points: 186
Electrical outlet sealers versus draft sealing
I don't think I need electrical outlet sealers because I found no drafts after sealing the back wall with spray foam.
Still, this puzzles me: they make foam electrical box sealers. You put them behind the wall plate and they prevent a draft from coming around the wall plate and switch/outlet/whatnot.
Think about this.
There's a draft behind the wall.
Isn't cold air moving in, circulating behind the wall, turning the entire drywall slab into a hugely efficient cooling/heating pad and defeating the purpose of any insulation you actually have in the wall? I mean my wall was 20 degrees colder than the rest of the room when I had a draft--the wall itself was 54F, the adjacent wall was 75F.
Instead of sealing the outlets, I've been sealing the wall itself and caulking around the door frame (the door jamb was just nailed on; you can look between a 3/16 inch crack and see outside, not to mention the mass airflow coming through...), along with putting in insulating batts that aren't just stuck in the wall with a huge cavity on every side (in direct contact with neither the sheathing nor the drywall for over 90% of the surface, and not contacting the studs). There simply isn't a draft behind the wall anymore.
Did it ever make sense? I think it's just a gimmick. If you need this, you have a much bigger problem that you need to solve instead.
If you can't explain why, then you don't know what you're talking about. I'll keep asking until I find someone who does.
bluefoxicy is offline   Reply With Quote
Old 12-30-2013, 08:15 PM   #2
Rewards Points: 1,862
DIY's are always looking for the quick, cheap magic fix.
Old 12-30-2013, 08:19 PM   #3
Rewards Points: 186
This "cheap, magic fix" seems to work like those $MAJOR_REPAIR_OF_THE_WEEK-in-a-can engine treatments that claim to fix everything from failed seals to bent rods in your engine without actually opening it up. Those mostly do actual damage to your engine--typically by either gunking up the oil filter or the galleys, causing a reduced oil flow and faster engine wear; sometimes they screw up the catalytic converter.
In this case it seems like pouring sawdust into your oil: the engine is broken, something is severely wrong (probably a sticking valve), but this makes it quiet so you can't tell it has a problem that's still there (and still causing a loss of power, poor emissions, etc.).
Old 12-30-2013, 09:29 PM   #4
Registered User
Rewards Points: 526
The poly ones are useful to stop any moisture from going to the wall cavity and condensing on the outer half of the stud at outdoor temp. They also keep humid indoor air from contributing to the stack effect, natural or mechanical, if you missed any top plate holes to supply your attic ventilation system. http://www.wag-aic.org/1999/WAG_99_baker.pdf
Make sure to get them all; http://www.greenbuildingadvisor.com/...-through-house
You can always do a "blower door" test to check your work; http://www.homeenergy.org/show/artic...r/1995/id/1173
With fiberglass, you still need a six-sided air barrier to get rated R-values; https://docs.google.com/viewer?a=v&q...M8l_EeA2F-qvvA
And even blocking the sheathing cracks, holes, etc., you still may get convective looping inside any low-density fiberglass batt= R-19, R-13, R-11; pp.45-48;http://www.buildingscienceconsulting...Measure_Up.pdf
Sealing the sheathing is a good idea, as I've said on here a few times before;pp.21;http://www.engr.psu.edu/phrc/trainin...ngbarriers.pdf
As your house is pressurized, the RH in the room air is forced into the wall cavities and the FG R-value is reduced from moisture condensing there to loose 60-70%; http://archive.nrc-cnrc.gc.ca/eng/ib...ling-heat.html
I spent the few $$ on outlet covers years ago, with or without a draft.
Gary
Old 12-30-2013, 09:44 PM   #5
Rewards Points: 186
Gary, you're saying that the whole "use these to stop cold air coming into your house" angle is a gimmick, but that they're actually intended to address an entirely different issue?
My house gets negative pressure from home air blowing out the chimney. As for low-density fiberglass, I'm running high-density mineral wool batts (Roxul 5.5 inch R-23 in 2x6 walls). It's not as good at handling moisture as real wool, but it handles moisture better than fiberglass; and being denser, I assume it's better at preventing convective looping.
Odd: the pressure thing carrying moisture in demands an interior seal; yet sealing the sheathing creates a sealed space, which then... yeah, now you have a moisture trap, not recommended. There's a combination of good things here that need to not be used together.
Old 12-30-2013, 10:43 PM   #6
TWX
Rewards Points: 35
I took a firestopping and penetrations class a few weeks ago, and it well could be to prevent smoke and overpressure from a room with a fire in it from spreading into conduit or into the wall, to leak out through the cover in another room.
TWX is offline   Reply With Quote
Old 01-01-2014, 12:26 PM   #7
Registered User
Rewards Points: 526
"Gary, you're saying that the whole "use these to stop cold air coming into your house" angle is a gimmick, but that they're actually intended to address an entirely different issue?"----------------------------- no, I didn't say that. I gave you another reason why to use them, because you already sealed the exterior sheathing cracks/plate holes/exterior light boxes. So you eliminated one reason to use them by doing that. Air seal the drywall (ADA) before you install it to help keep moisture from your MW insulation; http://www.dow.com/scripts/litorder..../179-04569.pdf
"My house gets negative pressure from home air blowing out the chimney."--------------- isn't that expensive to heat?
"Odd: the pressure thing carrying moisture in demands an interior seal; yet sealing the sheathing creates a sealed space, which then... yeah, now you have a moisture trap, not recommended."----------------------- you are confusing a double-sided vapor barrier with vapor permeable drywall (50perms) and plywood sheathing (10perms/OSB=2perms) which do let moisture out in a vapor form.
Gary
Old 01-01-2014, 01:17 PM   #8
Rewards Points: 6,652
When I did mine, and have been asked to go to friends homes and do draft sealing for them, I use DAP foam in the can, that is water clean up. Then just place the foam gasket inside the plate, place back on the outlet.
As for around windows & doors, same thing with the DAP foam. We have retro-fit windows, and I got tired of the drafts coming through them. Took the moldings off, and found out that whoever installed them, used very little insulation around the edges.
I also use the Z style Foam Weatherstripping around entry doors to the outside & garages, on older doors, or doors that are starting to kick out, where there is a gap between the edge of the door and the installed weatherstripping in the frame. Helps a lot to stop drafts.
It is surprising after you start sealing gaps, how much warmer the home is.
Old 01-01-2014, 01:23 PM   #9
Gary, after we removed the old chimney for the old Octopus furnace and draft water heater out of the roof, patched the hole, I have seen our humidity go up in the attic. I am going to have to get up there and put in baffles along the roof edge, and probably look at doing something with the Bath Fart Fan, since that is what is my possible culprit.
RH was lower up in the attic before the Chimney came down, so just making that one change in the roof, changed air movement through that space.
The Following User Says Thank You to gregzoll For This Useful Post:
Gary in WA (01-01-2014)
Old 01-01-2014, 01:28 PM   #10
Rewards Points: 186
It's a standard 1991 furnace design: the input air for the blast furnace comes from the basement. You can reach in and touch the burners if you want, even roast marshmallows on them or use them to light cigarettes.
Newer designs run an intake pipe through the wall to draw in outside air, loop it past the blast furnace, then eject it out the chimney.
I coated the entire wall with closed-cell polyurethane spray foam. Like so.
Old 01-01-2014, 09:55 PM   #11
Registered User
Rewards Points: 526
Enclosing the furnace in a room with its own supply air could only help your heating bill, IMO. An added benefit of SPF is air-sealing. Why was the lap siding on the wall, the boards will move with the changes in humidity of the seasons with that thickness of foam. (Unless you filled the wall after video). I saw some air gaps between boards that will only get worse, is that an exterior wall?
The foam on the roof sheathing requires more thickness than you added to prevent condensation and eliminate the ventilation there-- see the map;http://www.buildingscience.com/docum...n-roof-venting Or did you make more passes later?
Gary
Electrical outlet receptacle touching copper hydro pipe Jimmyswo Electrical 8 11-17-2012 10:27 AM
2ft Wall/Hallway Electrical Outlet Question?? hatchekc Electrical 1 07-17-2010 08:51 PM
HELP Installing Fault Interrupter Electrical Outlet!!!! pancho12 Electrical 5 06-15-2010 04:38 PM
Help with adding electrical outlet bowanna03 Electrical 5 05-23-2010 07:00 PM
Adding an electrical outlet box helpless handyman Electrical 14 07-06-2007 07:59 PM
