Durofoam Or XPS For Basement Wall? - Insulation - DIY Chatroom Home Improvement Forum
Old 08-04-2017, 10:36 AM   #1
Rewards Points: 22
Durofoam or XPS for Basement Wall?
I am about to insulate my block basement wall with rigid foam.
Not sure whether to use EPS Durofoam or XPS.
Would like to use XPS, but where I live in Ontario you need
at least 2 inches of it to be a considered a vapor barrier, anything less
you will need to add a barrier. I don't want any poly vapor barrier. Also only want one and half inch.
As much as XPS seems to be the recommended board for basement walls I am leaning towards Durofoam. It has very low permability of .5 perms due to its protective films. So it meets code at any thickness. It is also less than half the price of XPS.
I will be framing wall after with roxul mineral batts then drywall.
Any advice would much be appreciated. I don't wan't to make any mistakes.
Todd V. is offline   Reply With Quote
Old 08-04-2017, 03:57 PM   #2
Naildriver
chandler48's Avatar
Rewards Points: 336
Re: Durofoam or XPS for Basement Wall?
If the lesser priced item will suffice for the code requirements, I would go with that. Roxul is vermin proof, water proof, fire proof and mold proof, so no vapor barrier is needed between it and your final wall.
I know you have already seen it, but others may want to.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
surface drainage above a retaining wall Benjamin5 Landscaping & Lawn Care 4 09-26-2015 02:44 PM
Load Bearing Wall? Master Brian Building & Construction 3 06-05-2015 10:32 PM
Creating doorways/supporting wall issues NWVintage Remodeling 2 12-19-2012 03:19 PM
Retaining wall work-- what approach? emcelvaney Landscaping & Lawn Care 2 09-24-2012 07:49 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
