Ducts Insulation In Attic - Insulation - DIY Chatroom Home Improvement Forum
Old 10-06-2016, 02:01 PM   #1
Rewards Points: 2
Ducts Insulation in Attic
I have an older house and the HVAC ducts run through the attic. The insulation on them is pretty old and ratty. I am looking to replace it but not sure what product is best. I have read good and bad things about spray foaming ducts. Any advice as to what would be best?
civi19 is offline   Reply With Quote
Old 10-06-2016, 02:36 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 826
Re: Ducts Insulation in Attic
Where is the home.
Most important thing, before the insulation, is to have them sealed up properly.
Old 10-07-2016, 09:01 PM   #3
Rewards Points: 106
Originally Posted by Windows on Wash View Post
Where is the home.
and if they are metal, cleaned inside!
digitalplumber is just a name for use here, I am not a plumber!
digitalplumber is offline   Reply With Quote
Old 10-07-2016, 10:15 PM   #4
Rewards Points: 826
They are still seamed together. Be sure to mastic all the seams. At that point, you can just standard duct insulation, spray foam, or rigid foam if the runs are short and you are feeling especially industrious.
Attic insulation simagic Insulation 1 05-07-2014 12:06 AM
Attic Insulation Help Needed-What type, etc HandyFrank Building & Construction 9 12-15-2011 01:54 PM
Attic project - Would like opinions whataboutj Insulation 6 06-29-2011 03:07 PM
Fiberglass Insulation: How Do I Cover the Attic? chueh Building & Construction 3 11-08-2010 02:33 PM
Insulation over Attic Walkway BigJimmy Building & Construction 4 06-23-2008 02:13 AM
