Duct Insulation For Attic - Insulation - DIY Chatroom Home Improvement Forum
Old 06-06-2018, 10:35 AM   #1
Rewards Points: 6
Duct insulation for attic
I have a bunch of duct insulation I got for free. It has reflective foil backing on a fiberglass roll. Can I use this to help insulate my attic if I put it in my rafters? I don't necessarily need more insulation but since it was free I thought I'd take it. I thought it might act as some sort of radiant barrier. Would I just be wasting my time to put it up?
jzcrouse is offline   Reply With Quote
Old 06-06-2018, 12:16 PM   #2
Rewards Points: 2
Re: Duct insulation for attic
Donít think it could hurt
BayouRunner is online now   Reply With Quote
Old 06-06-2018, 01:22 PM   #3
Rewards Points: 166
We don't have your location and in some locations installing additional insulation in rafters can be a huge problem.
I assume you have insulation currently in your ceiling and none in the rafters.
Bud
Bud9051 is online now   Reply With Quote
Old 06-06-2018, 03:15 PM   #4
Rewards Points: 6
Im in Milwaukee Wisconsin. And I do not currently have anything up there. Its kind of unfinished storage space with insulation under the floor boards. Half the up stairs is finished.
Old 06-06-2018, 03:52 PM   #5
Guapo
Rewards Points: 11,950
If there are no ridge vents, gable vents or soffits, I wouldn't insulate. If you have vents & soffits, use foam board behind the insulation to maintain air flow & to avoid trapping moisture.
Guap0_ is offline   Reply With Quote
Old 06-06-2018, 03:53 PM   #6
Rewards Points: 166
An unfinished attic should remain uninsulated unless the space is completely converted and conditioned with heat and air circulation in summer. There are guidelines and codes that advise to not add insulation to the rafters as it creates a condensation zone that can cause roof damage.
Do you have any heat ducts up there?
The foil facing also acts as a vapor barrier so using it anywhere up there in a cold climate would require removal of that foil or placing the foil surface against the drywall. In a cold climate the foil facing should go next to the warm surface.
Bud
Old 06-06-2018, 04:09 PM   #7
Rewards Points: 6
I do have air ducts up there. They were wrapped in insulation when i bought the home.
Old 06-06-2018, 04:19 PM   #8
Rewards Points: 166
In addition to insulation any ducts in an unconditioned attic need to be carefully air sealed. Air leaking into returns or out of supply ducts is replaced by equal amounted through the homes envelope, a double penalty.
If they are flex ducts any connections need to be secure and sealed.
Generally when I hear the attic has board flooring it tells me there isn't enough insulation up there. Wisconsin was listed in the 09 energy codes as requiring R-49 in ceilings and they may have gone onto the 2012 or 2015 codes, unknown from here.
But r-49 is about 14" of insulation which pretty much eliminates any use of that space.
Bud
Tags
attic insulation
Is this fiberglass insulation safe (touching heating duct)? nutlog Insulation 7 12-13-2018 10:33 PM
Insulating your attic Bob Mariani How To Guides 5 07-07-2013 08:49 PM
Metal duct or flex? smokey982 HVAC 6 08-06-2010 06:20 AM
Q's about duct insulation veesubotee HVAC 3 12-13-2008 03:44 PM
Can I add insulation to a 6" flex duct? EE playing with HVAC HVAC 10 06-24-2008 06:07 AM
