Dryer Vent Going Through Insulated Wall - Insulation - DIY Chatroom Home Improvement Forum
Old 08-23-2018, 12:34 PM   #1
Rewards Points: 36
I have a dryer vent I want to pass through an insulated wall cavity. I wondered what the proper method would be to seal around the vapour barrier (the hole I cut in the poly sheet)as it passes through ? Tuck Tape ok ?
weehaggis is offline   Reply With Quote
Old 08-23-2018, 02:50 PM   #2
retired framer
Rewards Points: 748
Re: Dryer Vent Going Through Insulated Wall
Tuck tape I think is the industry standard. But if you are close to the dryer heat could be a problem so you might use sheet metal too.
Old 08-23-2018, 04:00 PM   #3
Rewards Points: 36
The drywall/vapour barrier exit point is about 10ft from the dryer itself.
Dryer Vent in the wall where new shower curb intersects Eclipse99 Kitchen & Bath Remodeling 4 10-19-2015 11:11 PM
Dryer vent location close to DWV vent WillK General DIY Discussions 4 10-05-2015 11:09 AM
dryer vent connection ieee488 Appliances 11 11-07-2012 07:00 PM
Vent a Dryer through a Flat Roof or run 21' out the wall? Integraoligist General DIY Discussions 4 02-03-2011 08:36 AM
Dryer vent. kcrossley2 Plumbing 10 02-20-2008 12:02 AM
