Drop Ceiling With Fiberglass Batts On Top. - Insulation - Page 2 - DIY Chatroom Home Improvement Forum
Like Tree6Likes
Old 11-28-2019, 01:23 PM   #16
Dave Sal's Avatar
Rewards Points: 26
Re: Drop ceiling with fiberglass batts on top.
Originally Posted by Guardian View Post
Ice accumulated above my sprayfoam by tiny cracks that let condensation in. I know this because IT RAINED inside when it melted in spring!!
Originally Posted by Bud9051 View Post
Sounds like no drywall, thus no air barrier, a very important layer. In your cold climate warm air will be leaking through the ceiling assembly and meet a cold roof, thus condensation and ice.
Bud
Looks like Bud was right after all.
Dave Sal is offline   Reply With Quote
Old 11-28-2019, 02:09 PM   #17
Rewards Points: 82
Not only is there drywall.. but I also caulked every crack i could find hoping that like people like Bud had said that an air barrier was possible. it's not. Hot air inside - cold air outside only needs a millimetre hole like from an old screw or like the giant gap between the wall and foundation shelf along the wall. a thousand and one places for air to get sucked up and impossible and silly to try to plug them all. And I didn't even want dry wall i had to put it in because of the fire code. So not only did have an ugly drywalled garage, but now it's crumbly wet plaster sandwiched between 2 pieces of paper. Huge mistake. Now if i have to use foam, and i don't like to because its so flammable, i use rigid foam and then just a can of spray foam to seal it. That way i can rip it out if need be. There are so many foam contractors out there pushing the virtues of spray foam. and lobby groups like green building advisor appears to be. beware.
Guardian is offline   Reply With Quote
drop ceiling installation? GEARS800G Building & Construction 2 04-30-2016 09:33 AM
Drywall Drop Ceiling Hoosiers87 Building & Construction 5 03-10-2015 03:45 PM
Drop Ceiling Idea buildit45 Building & Construction 11 12-06-2012 01:09 PM
Drop Ceiling removal alewiska Remodeling 14 12-12-2011 04:05 PM
Cans in a drop ceiling with 4" clearence RegeSullivan Electrical 3 04-27-2009 10:55 AM
