Draft Coming In Under Baseboard. - Insulation - DIY Chatroom Home Improvement Forum
Old 11-09-2014, 11:28 AM   #1
Rewards Points: 109
Draft coming in under baseboard.
Have a circa 1900 house with the original maple flooring and baseboard. We have a room that we opened the wall cavities from the outside, used cans of spray foam at the bottom, closed walls up and still have a draft coming in under the baseboard. The basement has been spray foamed from the inside. Is there a way to close up this draft. We apparently have not found the spot where it comes through. We couldn't believe it when we felt it. Thought sure we had gotten it on the third try. I'm currently thinking of taping out the edges of floor and baseboard and using a can a sprayfoam at the joint on the inside to get it closed up. Will that do it?
MaineLL is offline   Reply With Quote
Old 11-09-2014, 12:06 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 942
Balloon frame house?
You have a bunch more to do I order to stop the drafts.
Old 11-09-2014, 12:12 PM   #3
Rewards Points: 1,906
If it's balloon wall construction those walls are open from the crawl space or basement to the attic.
It should have been fire blocked before insulation.
Makes a great chimney in a fire.
Old 11-09-2014, 01:17 PM   #4
Rewards Points: 109
Ahh. Yes, balloon framing. I see how that could be the culprit. Will think further on this. It's also a rock foundation with an inside and outside layer of brick at the top of the foundation wall.
Old 11-09-2014, 01:36 PM   #5
Rewards Points: 388
The same thing happens with today's construction where the dry wall wasn't glued to the top plate and cold attic air travels down the wall behind the sheet rock and out from under the baseboards and from the wall outlets. This not only happens with outside walls but all interior walls as well. There are available insulation kits from the depot for the outlets. What a joke.
Old 11-10-2014, 09:57 AM   #6
Rewards Points: 942
You are going to have to air seal, fire block, and insulate.
There are a ton of good threads on balloon framing and what will need to be done.
If everything is done perfectly, you will still have drafts (albeit far less) as a result of the communication of the exterior/outside walls with outdoor air.
Help: Sewage smell coming from shower drain! erikerikerik Plumbing 23 01-11-2014 02:09 AM
Rotted Baseboard miamicuse Carpentry 11 09-08-2013 09:09 AM
Partial hydronic baseboard to radient floor conversion Jeepsail HVAC 4 01-17-2010 04:47 PM
Tempstar pilot not lighting after draft inducer replacement Kdavid HVAC 53 03-27-2009 02:10 PM
Toilet: water still coming from BOTTOM of Inlet Valve DIY Mom Plumbing 1 08-12-2008 12:43 PM
