Does This Stuff Always Sweat A Bit Inside The Plastic? - Insulation - DIY Chatroom Home Improvement Forum
Old 12-18-2019, 09:23 PM   #1
APA
Rewards Points: 382
Does this stuff always sweat a bit inside the plastic?
APA is offline   Reply With Quote
Old 12-18-2019, 10:05 PM   #2
Super Moderator
joed's Avatar
Rewards Points: 64
Re: Does this stuff always sweat a bit inside the plastic?
It shouldn't. The reason for the plastic is to keep the moist air out.
The Following User Says Thank You to joed For This Useful Post:
APA (12-18-2019)
Old 12-18-2019, 11:00 PM   #3
APA
Rewards Points: 382
The plastic is perforated.and is is open on top and bottom...
Old 12-19-2019, 04:57 AM   #4
Rewards Points: 136
Insulation needs to be covered with an air barrier. I've see many cases where people stapled up fiberglass insulation but did not install the drywall, maybe that is why they call it "dry"wall. But in any case the humidity from the inside air filters through and forms ice, sometimes lots of ice, against the cold sheathing.
Is that insulation pictured covered or exposed?
Bud
I volunteer my help and opinions, but you are responsible for what YOU choose to do with that information.
Bud9051 is offline   Reply With Quote
Old 12-19-2019, 08:15 AM   #5
Rewards Points: 1,948
If you're seeing water, it may be because you have them exposed and all the indoor air is mixing in. Once you cover the insulation, assuming the framing bays are air sealed to best ability, that moisture shouldn't be happening too much. Paint is also pretty good vapor retarder.
carpdad is offline   Reply With Quote
Old 12-19-2019, 01:56 PM   #6
Super Moderator
joed's Avatar
Rewards Points: 64
If the plastic is perforated then it is meant to be covered a vapour barrier.
