Does It Make Sense To Insulate In Here? - Insulation - DIY Chatroom Home Improvement Forum
Old 09-25-2014, 08:15 PM   #1
Rewards Points: 18
Does it make sense to insulate in here?
Would just stuffing some pink bat in these spaces make a difference? Both outside walls in the basement and the room above them walls are cold
Sent from my iPad using Tapatalk HD
Does it make sense to insulate in here?-imageuploadedbytapatalkhd1411694060.718514.jpg   Does it make sense to insulate in here?-imageuploadedbytapatalkhd1411694084.524507.jpg
Mdsjohna is offline   Reply With Quote
Old 09-26-2014, 06:01 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,054
Yes and no.
Yes on picture #1. There are a bunch of threads on here about sealing up band/ribbon boards. Well worth the investment.
No on picture #2 as it is laid out right not. You should really move some of that peg board out of the way and get all the way out to the ribbon board and seal it up prior to installing rigid foam.
If you have a froth pak of spray foam, you can probably still get to picture #2 and get it sealed up.
Old 09-26-2014, 06:16 AM   #3
Rewards Points: 1,918
No fiberglass insulation!
Use 2" blue foam and seal any gaps with spray foam.
Old 09-26-2014, 06:29 AM   #4
Rewards Points: 480
If you want condensation in there behind the insulation during cold weather then by all means insulate.
Old 09-26-2014, 06:59 AM   #5
They will not have condensation behind there if they insulate with a proper SPF or combination of rigid foam and sealant (foam or caulk).
I know that you know this I was just pointing out that there are different ways to insulate that space and you are correct if they just put some fiberglass or other insulation up there that will allow the moisture to permeate through.
Old 09-26-2014, 09:17 AM   #6
Rewards Points: 18
So on pic one cut blue foam to size install and caulk? Second picture I'm not understanding. There must be insulation behind the pegboard? I would need to move it just so I have better access?
Old 09-26-2014, 12:23 PM   #7
Removal is just for the easier access.
Does it make sense to change the roof line? jeffreyropp Roofing/Siding 4 02-25-2014 04:36 PM
Best way to make a roof exit or door? swaff Roofing/Siding 5 10-22-2010 01:15 PM
Best way to make 45 degree mitre jig BobS0327 Carpentry 7 09-21-2010 11:53 PM
Does this make any sense? fw2007 Electrical 10 07-24-2008 04:48 PM
Does ridge venting make sense if I do not have eaves/soffits? nymark Roofing/Siding 15 06-18-2008 10:59 PM
