Does Bottom Half Of Concrete Knee-wall Have To Be Insulated? - Insulation - DIY Chatroom Home Improvement Forum
Old 02-23-2016, 10:37 AM   #1
Rewards Points: 2
Does bottom half of concrete knee-wall have to be insulated?
We live in Oakland, California. We have an unfinished basement that we would like to finish up and insulation is on our list. The house was built in 1920. The basement is rimmed with a knee-wall foundation and the top half is framed out with studs that sits on top of the knee wall. We want to level out the wall and get rid of the "shelf" that the knee wall creates. Do we have to insulate the bottom half? Or is insulating the top half so it juts out and evens out with the knee wall enough to keep warmth in the basement?
jet2dresq is offline   Reply With Quote
Old 02-23-2016, 11:43 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 878
Insulate the bottom half as well.
Rigid foam works well in most basement masonry wall applications.
Old 02-24-2016, 09:44 PM   #3
Registered User
Rewards Points: 526
Welcome to the forums!
R-5 foam or R-13 cavity insulation is required for your location, per Code. Though I'd take that with a grain of salt... your coldest 3 months average temp is 52*F above-grade. 6' below-grade the earth is warmer at 62*F. depends on inspection or not... . Could just add some builders paper and fiberglass batt on the lower 1/2;http://www.diychatroom.com/f103/usin...362354/index2/
Fix any visible water signs/problems first.
Gary
new knee wall in existing cathedral ceiling rtoni Building & Construction 0 07-16-2013 04:52 PM
Mounting 60" LCD to thin concrete wall flatblackstrat Concrete, Stone & Masonry 7 02-18-2013 07:21 PM
Hydronic baseboard mounted to concrete wall Maine1 Remodeling 20 12-26-2012 06:08 AM
Converting Attic Knee Wall Space to Insulated Closet gigascott Building & Construction 7 01-20-2011 10:08 AM
Does the bottom half of basement wall has to be insulated? Johnny Ren Building & Construction 29 12-16-2010 09:18 PM
