Distinguishing Open Vs Closed Cell Foam? - Insulation - DIY Chatroom Home Improvement Forum
Old 03-26-2016, 02:28 PM   #1
Rewards Points: 332
Distinguishing open vs closed cell foam?
Is there a way to tell if an already installed spray foam is open or closed cell?
gizzygone is online now   Reply With Quote
Old 03-27-2016, 11:13 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 928
Re: Distinguishing open vs closed cell foam?
CC SPF is much denser and less compressible.
If you can squish it a bit, it is more likely OC SPF.
Old 03-27-2016, 11:57 AM   #3
Rewards Points: 332
The stuff I have is pretty dense, but if you pull a piece and squeeze it will give.... But it's nowhere near as compressible as, say, a packing peanut.
Old 03-27-2016, 12:02 PM   #4
Rewards Points: 928
Closed Cell is very hard.
Any experience with closed cell Polyurethane foam on ceiling jogr Insulation 6 02-11-2015 06:27 PM
Best Spray Foam Brand (Open Cell) kim_tx Insulation 7 04-17-2014 07:54 AM
closed cell spray foam for waterproofing? dads fixit Insulation 4 03-03-2013 08:31 AM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
closed cell vs open cell foam insulation amonalisa Building & Construction 1 11-06-2008 09:39 PM
