Delicious Delicious (moisture) Sandwiches - Insulation - DIY Chatroom Home Improvement Forum
Old 07-19-2015, 01:45 PM   #1
Rewards Points: 33
Anyone an engineer type? Familiar with moisture sandwhiches?
My new porch from the inside-out will be:
sheetrock, polyethylene sheeting, denim insulation, expanded polystyrene (white, 3/4"), osb, tyvek extruded polystyrene (pink 1/2"), vinyl siding.
Curious if anyone thinks or has any information that will help me determine if the EPS - OSB - Tyvek - XPS layering will cause moisture sandwich problems.
I'm thinking it'll be okay now, but before I do it and close everything up, better to see differing opinions.
Ghengisconrad is offline   Reply With Quote
Old 07-19-2015, 03:57 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 928
EPS is very vapor open so it can dry to that side.
Where is the home located?
Typically, foam on two sides of the wall is a bad idea no matter the foam.
Old 07-19-2015, 06:17 PM   #3
Rewards Points: 33
Fargo, ND. So... super hot summers. super cold winters.
From what I've read XPS is as vapor permeable as Tyvek, if not more; and EPS is more vapor permeable than XPS, so its like osb wrapped in 3 layers of Tyvek; that bad?
Old 07-23-2015, 07:24 AM   #4
Rewards Points: 928
Ghengisconrad (love the name by the way as that is what I call my one pup...Ghengis),
Gary notified me that you had replied. He is great to have as a sort of extra notifying system when he "polices" the boards.
That is likely the definition of a moisture sandwich depending on how the XPS is skinned.
See the perm table here.
If the XPS is poly skinned, you have a nightmare waiting to happen. General building procedures are moving away from poly on the interior but I do know that certain parts of Canada still require it.
http://www.buildingscience.com/docum...roperty-table/
Old 07-24-2015, 11:44 PM   #5
Registered User
Rewards Points: 526
1. Poly should NOT be used for your location. 4-5 cooling months with the AC on will give condensation trapped in the wall, esp. when using denim (cotton) that holds water in it to rot the wood framing.
2. Use a polyamide sheet or asphalt-faced FG for the vapor barrier, OR increase the exterior foam thickness to go without one; http://www.certainteed.com/resources/30-28-080.pdf
Either R-10 or R-15 foamboard in your Zone 7; http://www.buildingscience.com/docum...r-requirements
http://www.reca-codes.org/codes2006/North%20Dakota.pdf
2x4 or 2x6 wall? Gary
PS- Tyvek (drainable-- or stucco-wrap, loose nail siding per instructions not compress foam) should be on exterior of foam, then window install.
Excessive moisture rediris Building & Construction 1 04-21-2012 09:43 PM
Moisture Barrier Behind AND on Top of Cement Board JasonCA Remodeling 0 04-07-2012 01:31 PM
To Moisture Barrier or Not to Moisture Barrier? cordon Flooring 7 05-22-2007 09:48 PM
moisture barrier - help! jediracer Carpentry 12 10-03-2006 06:32 PM
Concrete slab weeps moisture dale h Flooring 2 04-30-2005 10:29 AM
