Cutting Foam Board Insulation? - Insulation - DIY Chatroom Home Improvement Forum
Like Tree7Likes
  • 1 Post By ktownskier
  • 1 Post By bassadict69
  • 1 Post By Yodaman
  • 4 Post By ktownskier
Old 07-25-2019, 12:22 PM   #1
Rewards Points: 381
Cutting foam board insulation?
Can I use my tablesaw to make my cuts?
I am insulating the roof of my metal shed and it is about 46 inches between the small joists on the roof so I need to cut a couple inches off the width of each sheet and am wanting nice straight cuts.
bassadict69 is offline   Reply With Quote
Old 07-25-2019, 12:27 PM   #2
retired framer
Rewards Points: 924
Re: Cutting foam board insulation?
That sounds messy, maybe with the finest blade you have.
Do not use flat bottom gables with scissor trusses.
https://www.fema.gov/media-library-d...6/chapter7.pdf
figure 7-14
The Following User Says Thank You to Nealtw For This Useful Post:
bassadict69 (07-25-2019)
Old 07-25-2019, 01:37 PM   #3
Super Moderator
joed's Avatar
Rewards Points: 140
You can use the table saw. Unless you have a vacuum system there lots of flying dust that will stick to everything via static.
The Following User Says Thank You to joed For This Useful Post:
Old 07-25-2019, 02:29 PM   #4
Rewards Points: 226
easiest way I've done it is to take a metal straight edge and a razor blade (new). Clamp the metal straight edge to the foam, and cut with the blade. If the foam is thicker, it should snap OK if you cut most of the way through. the only issue is that you're only cutting a few inches off a big sheet, so the snap isn't quite as easy as if you wree cutting them in half.
also note, if it has a shiny coating that needs to be cut on both sides as it doesn't just snap.
That was the method I used for 2" XPS
Spyder is offline   Reply With Quote
The Following User Says Thank You to Spyder For This Useful Post:
Old 07-25-2019, 03:02 PM   #5
Rewards Points: 4
Or, make a hot knife out of a soldering gun. All you need is a thin nichrome wire between two electrodes that you can control with a switch. There are specialty products to make clean cuts but they can cost quite a bit.
Nealtw likes this.
The only stupid question is the one you DON'T ask!
ktownskier is offline   Reply With Quote
The Following User Says Thank You to ktownskier For This Useful Post:
Old 07-25-2019, 05:25 PM   #6
Rewards Points: 381
I needed to cut 4 inches off the width of my first sheet so decided to give the table saw a try. I made my first cut long in case the saw didn't work well... it cut it beautifully! Clean, smooth cut with no more dust created than plywood creates sawdust, maybe even less.
Nealtw likes this.
The Following User Says Thank You to bassadict69 For This Useful Post:
Nealtw (07-25-2019)
Old 07-25-2019, 05:57 PM   #7
Property Mgt/Maint
Rewards Points: 26
If you are cutting a lot of the stuff, eventually it gums up the blade and starts pinching and burning. What I found that helps is to wax the blade with a old stick candle. With the blade off rub the wax on the sides of the blade.
Hope you are doing it outside, because it does make a mess!
Hooking up a shop vac to the exit chute helps if available.
bassadict69 likes this.
[political signature removed]
Yodaman is offline   Reply With Quote
The Following User Says Thank You to Yodaman For This Useful Post:
bassadict69 (07-26-2019)
Old 07-25-2019, 06:37 PM   #8
Rewards Points: 4
If you are doing a lot, you can also buy a special foam cutting blade for a circular or table saw.
Old 07-26-2019, 07:38 AM   #9
Rewards Points: 381
I will be cutting about 6 sheets total and yes, definitely doing it outside.
